[GAMBIT] Mesh Not Generate
Old   August 28, 2012, 02:00
Default Mesh Not Generate
ali
alimisaghian is on a distinguished road
Hi , i am modeling a granullar bed reactor. i have made the geometry that consist of the chamber and the granuls . the chamber Diameter is 25 cm and the granuls are 3mm Diameter. when i try to mesh it in gambit , it fails to mesh. please help me. What to do
alimisaghian is offline   Reply With Quote
Old   August 28, 2012, 03:48
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
any pictures or more details on errors given from Gambit?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 28, 2012, 03:56
ali
here a pic
Old   August 28, 2012, 03:59
-mAx-'s Avatar
Maxime Perelli
2d or 3d?
did you use a size function for refinining at holes?
Old   August 28, 2012, 04:06
ali
it is 2d , no idont know how to use that
Old   August 28, 2012, 04:12
ali
fluid will come from the top , and those circles are the solid granul. fluid will pass through them and will exit from bottom.
Old   August 28, 2012, 04:15
-mAx-'s Avatar
Maxime Perelli
ok I assume you have at top and bottom domains without holes, which means you can afford to get coarser mesh.
The area you displayed has to be mesh with small size elements, else you won't be able to capture anything.
So 2 options:
1-you have your domain (just one surface) and you mesh it with a constant element size (but small one: you need at least 8-10 element between holes)
2-you split your domain into 3 domains: top-center-bottom
you start with center domain, and apply size function on each hole edge, with small start size. Gambit will mesh the domain and refine at those edges. Then mesh the 2 other domains mith more coarse mesh (you can also use size function)
you will get smaller mesh size, but sufficient refined.
The problem you got should be linked to your element size (I assume)
Old   August 28, 2012, 04:16
ali
when i use Tri pave mesh with 0.11588 interval size the mesh is generated like this and fluent dont accept it .
Old   August 28, 2012, 04:20
ali
please check these pics,
Old   August 28, 2012, 04:28
-mAx-'s Avatar
Maxime Perelli
as you can see on your second picture, the mesh is to fine where there is no hole, BUT to coarse where there are holes.
Follow my advice 2-
Old   August 28, 2012, 04:33
ali
ok, thanks, let me check your advise 2 and report the results,
Old   August 28, 2012, 04:44
-mAx-'s Avatar
Maxime Perelli
just a tip for the size function with edges (holes)
Befor selecting edges, select All edges in the display attributes and visibility on. Then select All surfaces and visibility off.
Now only edges are displayed.
Click reset, and again in Edges, but select the outer edges (not the holes edges), and visibility off.
Only holes edges should be displayed
Now in the size function panel, you can pick and select all edges which are displayed.
you will save lots of time intead of picking all your edges one by one...
gambit, mesh erorr
[ICEM] How to generate this kind of mesh? mingersai ANSYS Meshing & Geometry 51 February 16, 2017 08:32
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[GAMBIT] how to generate orthogonal mesh using GAMBIT? ivanbuz ANSYS Meshing & Geometry 8 October 21, 2009 04:41
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 08:08
generate different mesh in CFX_MESH Eric CFX 0 June 23, 2006 10:09
