[ICEM] meshing a sphere - large deviation from perfect sphere
Old   August 14, 2012, 10:52
mjgraf is on a distinguished road
wanted to mention, when running CFX (most likely other solvers too), best practice is to run double precision with y+ <= 1
try this with CFX and see if your problem remains. If you are already running double, hmmm.
mjgraf is offline   Reply With Quote
Old   August 14, 2012, 11:14
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
This is correct for turbulent flows, where Yplus<1 can (usually) only be achieved with very thin cells (high aspect ratio) in the boundary layer.
In this case, I couldn't find any difference between single and double precision.
flotus1 is offline   Reply With Quote
Old   August 14, 2012, 11:46
reread, this is laminar flow.
interesting.
Old   August 15, 2012, 07:59
Max
murx is on a distinguished road
Yes it is laminar. The y+ value is very well below 1.
Double precision also did not make any difference in my simulations.
flotus1 sent me his fluent file. Unfortunately, I was able to discover a similar mesh-imprint in the pressure profile as in my CFX results. The attached picture shows the pressure profile obtained from the fluent run.
I know that this effect is not very strong. But since I my goal is to investigate the forces acting on the sphere, this is something I cannot ignore.
murx is offline   Reply With Quote
Old   August 15, 2012, 12:53
flotus1's Avatar
Alex
As I said already, the mesh should be created with a lot more patience than I had. In my file, the "imprint" doesn't come from the irregular radius of the sphere, but from the size and angle change between two blocks. This effect can be minimized with a proper mesh, but will never vanish completely.
The only other choice you have are tet or poly meshes. Here you won't see any imprint from the mesh. Nevertheless, the results will be less accurate than with a hex mesh.
Old   August 15, 2012, 13:37
Max
Yes, I guess you are right.
Although the irregularities only occour directly on the sphere surface and not along the whole block-edge and only when the sphere is rotating. But still... I also do believe it is the mesh. With the new blocking approach, mesh optimization reduced the irregularities a little.
So... thanks for the help. Case closed
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 15:18
[snappyHexMesh] Meshing a sphere with snappyHexMesh Cyberholmes OpenFOAM Meshing & Mesh Conversion 2 July 19, 2011 17:46
Meshing a sphere using ICEM lost.identity ANSYS Meshing & Geometry 1 March 13, 2011 21:19
Large U-tube modeing and meshing. Pradeep FLUENT 1 April 17, 2007 04:08
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
