Probems in Gambit: trouble linking two faces when a boundary layer is applied
Old   August 8, 2012, 09:54
Default Probems in Gambit: trouble linking two faces when a boundary layer is applied
Kathryn39 is on a distinguished road
I'm modelling flow over a cell and have created a box above it so I am basically dealing with a cube.
I have used GAMBIT's boundary layer settings to create a boundary layer at the bottom of this cube.
I then go to link two sides of the cube, their faces, as I want to apply a periodic boundary condition to it. However as the boundary layer is on the bottom if these two faces I am not allowed to link them and get this error;
"boundary layer b_layer.1 already attached to the edge.1:face.2 pair. This must be removed before attaching other boundary layers."
Is it possible to both have the boundary layer on a face as well as having it linked?
Any help would be much appreciated!!
Thank you very much!
Kathryn
Kathryn39 is offline   Reply With Quote
Old   August 8, 2012, 14:11
Andrew
mettler is on a distinguished road
hi -
I think if you uploaded a jpeg or some type of visual to help explain what you are doing you might get a good answer.
mettler is offline   Reply With Quote
boundary layer, face linking, gambit
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
gambit boundary layer meshing Rick FLUENT 7 May 5, 2016 14:29
Gambit boundary layer pixie Main CFD Forum 1 September 30, 2009 13:22
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
help for Gambit: 2 edges + 1 boundary layer Peter FLUENT 0 August 9, 2002 20:41
