[DesignModeler] Geometry working in GAMBIT but not FLUENT |
Colin Fiola
Rep Power: 14 ![]() |
I am new to the whole CFD world and am working on some test cases supplied by an organization. I have been supplied with an IGES model as well as some grid files with the .in file extension. I have also been supplied with .p3d file that is a pointmatch? Either way, I cannot get the full geometry to load in FLUENT but it will load in GAMBIT. What would be causing this. It seems it is easier to mesh in FLUENT so I would like to be able to do that. Also how can I import mesh's in FLUENT and what do .p3d and .in files do? Thanks in advance. |
Marion
Rep Power: 15 ![]() |
I dont know who told you that Fluent is easier for meshing, as it is not a software for meshing. It only reads mesh files (i.e. if you only import an IGES file it won't display anything as it is empty for Fluent).
Therefore you have to create the mesh before importing it into Fluent. You can do that with Gambit (and then file -- export --mesh) or within Workbench (design Modeller and Ansys Meshing). If you are new to the CFD world, maybe the 1st step would be to do some tutorials for beginners. Good luck, Marion. PS: No idea what to do with your .in and .p3d files. |
kunar
Dear friends,
In gambit its has the units default in millimeter or in meter? if it is millimeter whether i have to change millimeter in fluent also, because in fluent by default it is meter.please help me. |
misagh
gambit has no unit itself.it means don't care about the units in gambit.e.g if you want to create a rectangular 10*20 mm in gambit just create 10*20 (no unit) and then in fluent do this:
grid...scale...grid was created in(mm)...scale(at the bottom) |
kunar
misagh, thanks for information
kunar
Dear friends,
i am using gambit to draw my 3D wing,i create outer domain, the problem i face is my wing face & domain face are intersect i want to stick my wing face in one of the face, For that how i tilt either my wing face or my plane(face) to make a cantilever beam, please see my attached wing( in that red color shows wing face1, I want to stick face 1 to face2 like cantilever beam, then i want subtract my face 2 to face 1, please see the attached various position of image, please help me |
[GAMBIT] BC's value assignment in Gambit Vs. Fluent (solver) | hadikhayyamian | ANSYS Meshing & Geometry | 5 | December 21, 2010 12:28 |
SketchUp 3D model import to Gambit or Fluent | Steve Johnson | FLUENT | 0 | February 8, 2009 14:21 |
Gambit and Fluent Help | Vincent Ryan | FLUENT | 2 | January 11, 2009 07:34 |
Facing Few Problems in Fluent and Gambit | Ravi Duggirala | FLUENT | 5 | March 11, 2006 03:13 |
Input Geometry from Ideas to Gambit | Knick | FLUENT | 2 | December 11, 2002 03:59 |
