[ICEM] Why the mesh changes after I save and open the project again |
July 19, 2012, 10:28 |
lnk
Rep Power: 15 |
I made mesh for a complex geometry by ICEM. After I improve my mesh quality, I save it. Then I open that project and check the mesh quality right afterwards. The mesh quality becomes bad.(By slightly changing it, it will be good again.) May I ask that's why and how to avoid this problem? After I improve the quality, if I export that mesh to CFX, am I exporting the good mesh or the bad one? Best regards and many thanks, lnk |
October 26, 2012, 13:22 |
Rep Power: 14 |
hey, I have exactly the same problem. Is someone able to explain me what I've done wrong or if it's a bug?
I produce my block mesh or unstructured, it doesn't matter, then i use the command smooth mesh globally (that works on the unstructured mesh) to gain a good quality, I save the project and close Icem. When i open the saved project and i check the mesh quality I get a really bad histogram worst than the one that I had before smoothing. It doesn't happen with all the project I've done but with most of them. I forgot to say that all the projects are based on the same geometry. Thank you very much, regards Last edited by CFD-Cat; October 26, 2012 at 13:23. Reason: error |
October 29, 2012, 00:31 |
#4 | |
nitin bansal
Rep Power: 14 |
October 29, 2012, 03:29 |
Rep Power: 14 |
Nice I'm not alone! Anyone is able to give us an explanation?
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Question How to save Ansys 13 project to be opened by ansys 12 ? | rafiktharwat | ANSYS | 3 | July 17, 2017 22:09 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 11:40 |
Open ANSYS12.0 Workbench Project on another computer | Andrew | FLUENT | 2 | July 6, 2010 01:20 |
