[ICEM] Understanding check mesh output
Old   July 15, 2012, 09:33
Default Understanding check mesh output
Madhukara Putty
kotimari is on a distinguished road
I am trying to create a 2D mesh around a wind turbine airfoil by following the video tutorial prepared by ANSYS. After creating the mesh, I ran check mesh to find out that there are problems in the cells located near the boundary of the farfield and the airfoil. When I try to read the mesh in Fluent 13, I am getting the following the error message:
Error: Build_Grid: no cells in case file.
Clearing partially read grid.
Error: Build Grid: Aborted due to critical error.
Error Object: #f
My questions are:
1. How do I interpret Check mesh result?
2. How can I solve the issue?
Have attached a screenshot of the check mesh output.
Thanks for the help!
Last edited by kotimari; July 15, 2012 at 09:36. Reason: Had a look at posts pertaining to the error "no cells in case file". But, couldn't derive any help! I am a newbie-;)
kotimari is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
Mesh Check fails in OpenFoam ???? Gitesh P OpenFOAM 3 June 30, 2011 06:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
