[ICEM] Quarter O-grid topology for propeller blade
Like Tree24Likes
Old   August 27, 2012, 10:55
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by venkat_aero2007 View Post
Far you are too quick
I seen your reply after posting my last message. so do you mean that I have to keep same shroud height for both the rotors.
yes...................
M MOHSIN likes this.
Far is offline   Reply With Quote
Old   August 27, 2012, 11:12
Far
Sijal
yes I am giving both rotors motion with +ve and -ve rpms. It is not possible to give the one rotor rpm1+rpm2 and other one as stationary because in contra rotaing rotor, the front rotor rotates in clockwise and rear in anti clockwise direction. I am sure it is not because of meshing problem because I ran a simulation with unstructured mesh which worked perfectly fine.
Analogy: Aircraft moving with Mach 0.8 in free-stream and while solving in CFD we give air the velocity of Mach 0.8. Because it is relative to each other and we get the same effect.
Why I am saying this is because once I tried to solve the high pressure and low pressure turbine coupled with S-type diffuser with increasing radius. It was single stage high pressure turbine and two stage low pressure turbine and rotating in opposite direction. But i was not able to do this. What I concluded is that the mixing plane model availabe in commercial codes is only valid for rotor stator system with rotation in -ve or +ve direction and you can have more than 15 stages (or even more) but rotating in same direction.
So either you should modify the implementation of mixing plane model as did by following references or ask Fluent support if they have ever solved the contra rotating rotors (one in +ve and second in -ve direction) with available mixing plane model. For record this mixing plane model implemented in Fluent or CFX was originally developed by Denton and Dawes at Whittle Lab, Cambridge university.
Ref1 : https://stacks.stanford.edu/file/dru...-augmented.pdf
Ref2 : http://adl.stanford.edu/papers/AIAA-2007-1117-275.pdf
Ref3: http://adl.stanford.edu/papers/AIAA-3893-286.pdf
Ref4: http://adl.stanford.edu/papers/AIAA-2007-519-239.pdf
"why are you merging meshes in ICEM?"Actually the front rotor consist of 11 bades with peridic angle 32.72727 and the rear rotor with 9 blades (peridic angle 40). So meshes them seperately and merged it.
This should be done in Fluent. Output both meshes separately and glue them in Fluent with Append command. This is standard practice for mixing plane. Merging meshes in ICEM is done for other reasons.
Could please tell me how to change the domain geomentry shape.
Geometry shape looks fine to me. They only requirement for periodic boundary is that it must have same shape on both sides. For mixing plane I have already disccused in previus posts.
Old   August 29, 2012, 06:54
Far
Sijal
This may be helpful for you.
http://dspace.mit.edu/bitstream/hand...401.pdf?sequ..
I have also started thread on mixing plane model in CFX:
http://www.cfd-online.com/Forums/cfx...tml#post379262
Old   August 29, 2012, 07:04
Far
Sijal
You can model this as unsteady and still use the single rotor from both rotors using the advance models available in CFX or you can switch to NUMECA. ANSYS is updating turbo machinery models in CFX, not in Fluent.
http://www.numeca.com/fileadmin/news..._Corporate.pdf
http://www.numeca.be/index.php?id=41...ash=101540dfc0
http://www.google.com.pk/search?q=un...hrome&ie=UTF-8
http://www.google.com.pk/url?sa=t&rc...p14RIQ3REScuSQ
http://documents.irevues.inist.fr/bi...pdf?sequence=1
Old   August 29, 2012, 07:07
venkatesh
venkat_aero2007 is on a distinguished road
Hi far, thanks a lot for your information. I have discussed with my professor about the mixing plane model available in fluent. He said that the contra rotating simulation can be done just by giving one in +ve rotation and other in -ve rotation. I am going to start my simulation today. I will update the result soon
venkat_aero2007 is offline   Reply With Quote
Old   February 17, 2013, 02:49
Default link dosen't esist
  #46
AhmadReza
ahmadreza is on a distinguished road
I created quater O-grid and tried to adapt block as suggested in post 4. but could not get a fine mesh. I don't know where I am going wrong.
Firstly I made a horizontal and vertical split (Figure1) and then to create quarter O-grid, I selected 4 faces as shown in figure2. I thought of associating the edges parallel to the two curves (figure3). I made horizontal split at each section of the blade. then associated edges to curves. I tried to make a O-grid but ICEM should me an error message saying that O-grid not successful.
The mesh around the pressure side of the blade flows the profile of the blade (figure 4) but where as near the suction side, mesh does not follows the blade's profile (figure5). mesh near the trailing edge are clustered. The quality at the tip of the blade is also bad. should we want to do a special treatment
near the tip region.
Here are the files
https://www.dropbox.com/s/k28abvd4b3...quater%20O.prj
https://www.dropbox.com/s/indjfxjj4b...quater%20O.blk
https://www.dropbox.com/s/8vcbc6uod3...quater%20O.tin
waiting for your suggestions.
hi . thanks for your gird . but unfortunantely your is link for download doesn't exist.
pleaze send me file (motaffef@gmail.com) or Correct this link , thanks alot
ahmadreza is offline   Reply With Quote
Old   February 13, 2014, 01:38
Default Help plz
  #47
M MOHSIN's Avatar
M Mohsin Iqbal
Location: National University Sciencies & Technology, Pakistan
M MOHSIN is on a distinguished road
SIR i m new to icem i want to rotate propeller in for cfd analysis plz guide me . looking forward
M MOHSIN is offline   Reply With Quote
Old   March 12, 2014, 03:56
AhmadReza
hi
you first told what is your question?
Old   March 14, 2014, 00:49
M MOHSIN's Avatar
M Mohsin Iqbal
Sir my question is how can i rotate the propeller using UDF or any other method i.e to give rotation to it. looking forward . thanks
Old   March 14, 2014, 15:52
AhmadReza
is your boundary condition periodic or not ???
if is not you can rotate your mesh in fluent with 1-rotation 2-append case
Old   March 16, 2014, 23:29
M MOHSIN's Avatar
M Mohsin Iqbal
sir it is not periodic i have to carry out at cruising speed so can u elaborate kindly how can i do it plz . . . . .
Old   January 31, 2015, 07:27
sattar
drsattar is on a distinguished road
Here are the files
hello
thanks for your work its very good but
please send me files to (hdrsattar@yahoo.com) or Correct this link
thanks alot
drsattar is offline   Reply With Quote
Old   February 22, 2018, 09:45
Mahendra Gupta
mhndrgpta is on a distinguished road
Hi, venkatesh, can u plz share video tutorial, given by Far on mahendra.kr.gupta@gmail.com?
mhndrgpta is offline   Reply With Quote
Old   April 4, 2018, 18:31
sery
sery is on a distinguished road
Hi Far,
Your link is dead.Is it possible to re-download it?Thanks
sery is offline   Reply With Quote
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
Algebraic Multigrid for nonuniform grid Joshua Lee Main CFD Forum 4 March 16, 2000 14:05
Non-uniform grid calculation Aspens Main CFD Forum 1 February 23, 2000 15:15
Grid Quality and the Solution Faraz Main CFD Forum 4 January 10, 2000 19:18
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 23:26
