[DesignModeler] Is it possible to change the sketch plane in DM? |
July 11, 2012, 19:58 |
Riley Gorder
Rep Power: 16 |
I am new to DesignModeler and ANSYS Meshing and I have ran into the following problem. I created a 2D surface in DM to mesh and export to FLUENT...
My problem is I created the surface in the YZ-plane and apparently I cannot export my geometry in 2D unless I create it on the XY-plane. This was not the case in Gambit, which I am more familiar with... Is there a way to move a sketch to a different sketch plane? Thanks for any suggestions |
July 11, 2012, 20:29 |
Figured it out!
Riley Gorder
Rep Power: 16 |
I figured it out after beating my head against the wall long enough! Here is what I did...
Export a script detailing the desired sketch.... File > Write Script: Sketch(es) of Active PlaneClick on the sketch plane you want your sketch in (in my case the XY-plane) and run the script. File > Run ScriptSimple solution... just not an easy one to pin down if you are used to other programs such as SolidWorks and Gambit |
July 12, 2012, 02:39 |
Rep Power: 14 |
I have also read in DesignModeler instructions from ANSYS about the function called "Sketch Instance". May be it will help the others. "Sketch instance allow you to place copies of existing sketches in other planes" (C) Best regards, Novosiberian |
July 12, 2012, 12:35 |
Comment about Sketch Instances
#4 | |
Riley Gorder
Rep Power: 16 |
Novosiberian:
I had tried that but it did not work in my case as I wanted to move the sketch to the XY-Plane. Here is a snippet from the ANSYS manual explaining it in more detail. Quote:
Riley |
design modeler, fluent, meshiing |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
Change cell zone index/thread during simulation | neilduffy1024 | FLUENT | 0 | January 17, 2011 09:40 |
Meshing a Mixing Plane in ICEM | Will Anderson | ANSYS Meshing & Geometry | 2 | November 9, 2010 09:16 |
Requesting plane properties: DEFINE_DPM_OUTPUT | Julian K. | FLUENT | 0 | December 21, 2008 05:44 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 07:16 |
