[ICEM] Blocking For Swept Wing
Old   July 11, 2012, 01:56
Default Blocking For Swept Wing
air_engineer_arsenal is on a distinguished road
Hi All
I am new on this community and came here to get some help regarding the blocking for a Swept Wing. Previously I have visiting the community as a guest and got a lot of help regarding wing meshing for a simple rectangular wing in the thread "Structured Hexa Mesh on Wing". I found a nice discussion and different blocking strategies for a rectangular wing which actually helped in understanding new things in ICEM CFD. Now I have a problem in hand regarding the CFD analysis of a simple swept back wing. I need help for blocking the wing. I need to know how the blocking strategy in the above mentioned thread will change when we have a swept back wing or is there a method entirely different for this wing. I am attaching my .tin file in this post. Looking for some good help
Regards
File Type: zip S1020_Swept Back Wing.zip (214 Bytes, 47 views)
air_engineer_arsenal is offline   Reply With Quote
Old   July 11, 2012, 03:40
Andrey
Ralen is on a distinguished road
Geometry file in attachment is empty.
Ralen is offline   Reply With Quote
Old   July 12, 2012, 01:13
Here are the .tin and .prj files
Regards
Old   July 12, 2012, 03:12
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
same blocking strategy will work fine.
Far is offline   Reply With Quote
Old   July 12, 2012, 12:06
Thanks Far for your reply. Can you please explain a bit how we will tackle the region in front of leading edge which is left empty(leading edge at root and tip is not aligned) by the swept wing as compared to rectangular wing and secondly the domain at the inlet is C-type but the blocking strategy explained for rectangular wing was with the rectangular type at inlet. so how to go about this? I am only confused in these two points, please help me clarify these. Thanks
Regards
Old   July 12, 2012, 12:52
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
About the C-Type geometry for the inlet, just initialize a block and do association according to the picture below, nothing really special. you will need to create an o-grid inside, and select face so the quality of your elements can be higher (see picture below number 2).
beside the ogrid, just perform you blocking as you are dealing with a rectangular shape. just try...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 12, 2012, 13:14
Far
Sijal
Or you can use the half o-grid (aka c-grid) and then another split at the trailing edge. And another split in ogrid to make the boundary layer meshing. I am attaching basic blocking and now your work is to associate inside edges to wing curves, and some working on blocks inside the tip region.
Old   July 13, 2012, 10:58
Thanks alot Far and Diamondx for your quick help. I have almost understood the procedure except few things. Far have you made vertical and horizontal splits in the main block before inserting C-grid or after the C-grid you made the slpits? and have you made the horizontal split in the main block above and below wing or its just the C-grid which I am considering the horizontal split?and last thing.... for inserting C-grid have you selected the face in front of leading edge or what else you did? Thnks
Regards
Old   July 13, 2012, 11:08
Far
Sijal
Regards
I did not make the horizontal spit al all. Vertical split is made after c-grid creation.
May be by horizontal split you mean the split on the edge in the z direction. It does not make any difference if you make it before c-grid or after it. But I prefer it after c-grid.
For C-grid I have selected three faces: 1) Symmetry 2) opposite to symmetry (side in above files) and outlet face.
Old   July 17, 2012, 04:22
Thanks a lot Far for your continuous guidance. I have done all up till the steps you posted in your blocking files but still confused in some things. I am splitting the tip block vertically and inserted Y-block for trailing edge and Ogrid for leading edge blocks. All is fine up till here. Now I have to associate edges to curves of wing and for that I merged the vertices at trailing edge using collaspe block command...Is this the right way to move forward? Then after associations we have to adjust the blocking for better quality. In rectangular wing it was simple as the root and tip are aligned so we aligned vertices(in straight line) to get blocks but here root and tip of wing is not aligned rather tip is swept back....so my question is do we align vertices in straight line as were doing in rectangular wing case or we need to align it along the direction of wing sweep for better quality mesh? which option is good? if later option is good for adjusting blocks then how it will effect other blocks? Thanks
Regards
Old   July 17, 2012, 07:11
the fallowing figure shows the blocking adjustment about which I was talking about in the last post, red lines shows the direction in which I am adjusting the tip block...is it right? and my effort's .blk and .prj file is also attached.
Old   July 24, 2012, 03:38
Far
Sijal
I got the duplicate blocks from files you have just uploaded.
Old   July 24, 2012, 12:21
sorry didnt get your point Far?
I am just asking about the direction in which blocking will be adjusted and also about the block split behind the trailing edge? Thanks
Regards
Old   July 24, 2012, 12:52
Far
Sijal
Your blocking adjustment is good enough. There were some duplicate blocks at the outlet and just deleted them. Also made some minor adjustments on vertices
blocking, tin and prj are attached
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 14:43
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 04:13
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails klausb OpenFOAM Meshing & Mesh Conversion 0 December 28, 2011 15:26
[Gridgen] Blocking topology for blunt wing siw Main CFD Forum 3 July 21, 2010 14:55
best blocking strategy for a wing profil tgrt18 ANSYS Meshing & Geometry 1 November 27, 2009 02:37
