[ICEM] merge vertex to edge explained by Video tutorial
Old   July 7, 2012, 10:44
Default merge vertex to edge explained by Video tutorial
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Hey I just come accross the ICEM command merge vertex-to-edge and found it very much useful in situation when we have the dissimilar edges/vertices on two blocks which are required to be connected. It has benefit in a sense that it is not always possible that we have corresponding vertices present at the required position in order to merge. Moreover it is not possible to create the vertices on edge at the exact locations in case of complex cases. Video link is here
http://www.youtube.com/watch?v=6qFVVyequM0
First pics shows the notes from ICEM help and second pic shows the snapshot from the present work.
Far is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
