[ANSYS Meshing] Multiple errors in ICEM and FLUENT
Old   July 5, 2012, 13:16
Angry Multiple errors in ICEM and FLUENT
Teyen Widdicombe
Evil Teyen is on a distinguished road
Hi all- I am trying to mesh a system of ducts (16mm x 1.4mm cross section) wrapped around a hot power source (250x250x370mm) in ICEM for use in Fluent. Numerous issues, this code is horrible- I even emailed ANSYS to tell them so and a man phoned me to say it was maybe "too high end" for what I was doing. Anyway. To the problems:
Firstly the auto-meshing option kept making an atrocious mess regardless of the settings, so after wasting a week I discovered the manual mesh building tools. I am now trying to build a single length/corner piece of ducting- it exports fine, but it causes FLUENT to throw an "ACCESS_VIOLATION" error on import. If I try to run the mesh checker it finds a variety of uncovered faces in both fluid and solid parts of the mesh, so I can't just add them arbitrarily to a new part with a defined boundary condition, but FLUENT seems to fix these before it crashes anyway- it also thinks that certain volume elements are incorrectly oriented (how I have no idea, as it created them itself- surely it should have known not to mis-orient them?) and if I click "fix" it bends them all out of shape, thus ruining the mesh. What can I do, beyond just cutting my losses (2 weeks of a ten week project so far) and re-starting in another meshing tool?
Cheers.
Evil Teyen is offline   Reply With Quote
Old   July 5, 2012, 14:26
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
relax... can you share pictures, icem files ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 5, 2012, 16:20
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I can understand ur feelings. Can you share some details so that we can help you out.
Far is offline   Reply With Quote
Old   July 9, 2012, 12:01
Teyen Widdicombe
Many thanks for the encouragement all! I do have images and ICEM files, however I have now re-started in Design Modeller. I have ten sub-channels in each duct:
and at least one length / bend will mesh in DM:
however, of the geometry for one complete loop (of 24 I shall eventually need):
only one channel will mesh:
and, besides telling me I have misoriented faces on the other 9 channels, which were created in exactly the same fashion as the one which will mesh (via the successive boolean union of subsections), I just got this phenomenally useful error message from MS visual C++:
which is fairly amusing in itself..
Update: managed to get the whole loop to mesh, about to run a sim on it
Old   July 9, 2012, 12:17
Teyen Widdicombe
Fluid channels:
in solid duct:
and the former after corruption by ICEM:
ruined volume orientations..jpg.
I may yet have to go back to ICEM to build a manifold the geometry for which I can't currently see a way to creating in DM.
access violation, fluent, icem, misshapes mesh, p.o.s code
ICEM to Fluent (2D Geometry): File has wrong dimensions? mullzer FLUENT 2 December 24, 2021 02:02
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 07:28
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
ICEM BC to FLUENT Simon CFX 3 September 9, 2008 18:08
