[ICEM] Meshing of a closed wing
Like Tree6Likes
Old   July 4, 2012, 12:19
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
according to a lots of posts in the forum. 0.1 can do the job... how many elements you got there. can you share your projet, i'll see if i can locate the bad elements for you. dont share the .uns file. its size is very big, share just the blocking
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 4, 2012, 12:22
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
check the quality in fluent. You should have orthogonal quality > 0.01. Other metrics are angle (in ICEM) which should be > 18 deg.
But you need to try, if solver does not mind the mesh quality of 0.1
Far is offline   Reply With Quote
Old   July 4, 2012, 12:31
Lukas Kadek
Lukas_ZH is on a distinguished road
I hope these are the correct files. Right now, the set curve parameters are rather high. But I couldn't find guidelines for the necessary size of the elements for viscid/inviscid case. For the inviscid case I would need to create smaller elements around the wing. Could I do that with the pre-mesh paramters and inflation of the surface or is there another possibilty (easier)?
Best regards,
Lukas
Lukas_ZH is offline   Reply With Quote
Old   July 4, 2012, 12:46
diamondx's Avatar
Ghazlani M. Ali
.tin file is missing ...
Regards,
Ali
Old   July 4, 2012, 13:10
Lukas Kadek
I renamed the files manually in the folder. Otherwise the original name was INVISCID for all of them, in case there some troubles appear due to the name.
Best regards,
Lukas
Old   July 4, 2012, 13:32
diamondx's Avatar
Ghazlani M. Ali
As you can see in the image above, bad elements are the results of the abscence of and ogrid inside the airfoil. I think these nodes will not be used for computation, i guess it's ok.
If your pc is not too strong to show bad elements, one thing you can do, unselect the premesh feature, like that you will only see the bad element. Another tip, use index blocking, and select premesh qualities to view the bad elements just inside the block selected in the index blocking. when number is reducing pc is more capable of showing them.
Regards,
Ali
Old   July 4, 2012, 13:44
Far
Sijal
http://www.cfd-online.com/Forums/ans...-icem-cfd.html
Lukas_ZH likes this.
Old   July 4, 2012, 14:42
Lukas Kadek
I decided to delete the blocks inside the airfoil. The pre-mesh statistics are within an acceptable range, but the statistics gained from the unstructured mesh don't seem that well anymore.
Are the statistics from the pre-mesh histogram more relevant than the ones from the unstructured statistics? If not, how can I try to get rid of the bad elements?
Old   July 4, 2012, 15:10
Far
Sijal
they should be same
Old   July 5, 2012, 07:57
Lukas Kadek
It works by now, though I can't say what I did differently. Thought everything stayed the same except for the sizing of the edges.
Best regards,
Lukas
Old   July 5, 2012, 08:16
Far
Sijal
Best regards,
Lukas
This might due to different premesh and mesh. In other words you have changed the parameters for premesh but did not convert it into unstructured mesh.
Old   July 6, 2012, 03:42
Lukas Kadek
Do you by chance know a source where I can find grid spacing (best practice) or resolution guidelines for an airfoil if I want to perform an inviscid simulation with Re=10^6 and Ma<0.3 ? I was only ale to find suggestions for y+ in the viscid case, but no suggestions for element sizes in the rest of the domain and how the domain should be in size related to the object around which the flow is supposed to be simulated.
Best regards
Lukas
Old   July 6, 2012, 06:19
Lukas Kadek
So I set a few parameters (linked edges, element number, spacing laws). Since I am new to the whole simulating enviroment I cannot estimate if that grid is useful for an inviscid calculation in Fluent.
Thanks in advance.
Best regards
Lukas
Old   July 6, 2012, 06:21
Far
Sijal
Although I have little experience in inviscid simulation, but I can recall something from memory.
1. There is no strict requirements in the normal to wall direction i.e. Y+.
2. I feel that the mesh should be fine enough in the areas of abrupt changes either in geometry or flow. I mean you should resolve the mesh in the region of shock waves, expansion corner and also in sudden change in geometry contour and sharp corners.
3. As a rule of thump, the inviscid mesh can be of 1/10th order to that of viscous mesh. (this is from my experience while reading the literature and my friends running the Euler solution , please correct me if it is wrong)
Old   July 6, 2012, 08:15
Lukas Kadek
Thanks once more
Best regards
Lukas
closed wing, mesh, o-grid
[GAMBIT] Meshing of flipper wing dv.darshan ANSYS Meshing & Geometry 9 May 21, 2012 02:38
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails klausb OpenFOAM Meshing & Mesh Conversion 0 December 28, 2011 15:26
Wing Meshing steve1 ANSYS Meshing & Geometry 1 July 5, 2011 10:14
Wing meshing help...... ACER Main CFD Forum 0 January 31, 2011 19:20
Meshing for 3D wing with tubercle on the leading edge in GAMBIT nvtrieu FLUENT 0 August 14, 2010 11:13
