[ICEM] hexa meshing
Old   June 25, 2012, 10:42
Default hexa meshing
tmeysam92
tmeysam92 is on a distinguished road
Hi all,
I have a simple question
I attached two pictures.
I want to mesh the cylinder in ICME like the quarter of cylinder meshing that i made in ansys meshing (sweep method).
i mean i do not have the center block in the center of cylinder, just like the quarter part, just radial meshing.
is it possible????/
thanks in advance,
meysam
tmeysam92 is offline   Reply With Quote
Old   June 25, 2012, 11:30
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
yes it's possible. you will then not use an o-grid.when you perform your initial block, merge to vertices to make it like a triangle then transform the block to an y-grid. it's much suitable for this situation. may be there is another blocking strategy , this one is the only i've got in mind now.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 25, 2012, 13:59
tmeysam92
Hi diamondx,
thanks a lot for reply
i did not understand.
i am just learning icem.
what kind of merge of vertices do you mean.
could you please look at the picture and tell me which kind of of merging do you mean?
Old   June 25, 2012, 15:15
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
First option. Also make the appropriate geometry
http://www.youtube.com/watch?v=92vSc...feature=relmfu
@ 7:44 http://www.youtube.com/watch?v=dHfAe_6weZE&feature=plcp
Far is offline   Reply With Quote
Old   June 26, 2012, 10:44
tmeysam92
Hi Far,
i could not solve my problem.
could you please mesh the cylinder in the same way that i said?
i really need that.
thanks in advance
Old   June 26, 2012, 13:30
Far
Sijal
For this, I used quarter o-grid instead of Y-block. But mesh/blocking will be same with both methods.
Old   June 26, 2012, 14:01
tmeysam92
so you mean that it is not possible to mesh without the center cubic part.
i want to be all radial mesh.
Old   June 26, 2012, 14:06
Far
Sijal
Possible. But in that case you will have the prism elements in the center
Old   June 26, 2012, 14:09
tmeysam92
i meshed the quarter of the cylinder in ansys meshing with sweep mesh. did you see the attachment?
i want to mesh cylinder like that. in that attachment there is just a few prism mesh.
[ICEM] Hexa meshing of impeller and diffuser assembly Nitin Dewangan ANSYS Meshing & Geometry 14 September 13, 2016 10:41
[ICEM] Hexa dominant meshing Pat84 ANSYS Meshing & Geometry 19 December 2, 2015 18:20
Wind tunnel hexa meshing in ICEM CFD 12.1 matheusguzella ANSYS Meshing & Geometry 1 March 14, 2011 17:14
Hexa Block meshes in ANSYS Meshing? siw ANSYS Meshing & Geometry 3 July 31, 2009 11:40
Hexa meshing or Tetra meshing??? NITIN DEWANGAN CFX 5 August 5, 2008 10:59
