August 14, 2012, 13:50 |
#22 |
John
Rep Power: 15 |
August 14, 2012, 14:07 |
#23 |
Stuart
Rep Power: 26 |
Since you used Meshing do you also have access to CFD-Post? In there it is simple to make planes through your pipe and plot contours or vectors on them. That is a good feature of Workbench by running through the entire simulation process and keeping all the files and data in order.
If you are using a Workbench analysis system, in your case for FLUENT, it will automatically sort out the results file for CFD-Post for you. Last edited by siw; August 14, 2012 at 14:09. Reason: typo |
August 14, 2012, 14:09 |
#24 | |
John
Rep Power: 15 |
March 20, 2017, 08:05 |
meshing in ansys
#25 |
PRADNYA
Rep Power: 9 |
hello,
how to slice the geometry and form sub surfaces for refining the mesh for a 3D geometry As i am finding it difficult as i am new to ansys. please suggest on it. |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Problem importing GAMBIT mesh to Ansys geometry | David G. | CFX | 0 | June 19, 2005 07:01 |
