June 21, 2012, 11:32 |
ANSYS WB Mesher really slow?
Rep Power: 14 |
Hej,
i ve some questions regarding the speed of ANSYS WB Mesher. I just ve a Fluid Mesh of ca 200000Nodes and an Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz as processor and 8GB Ram. So i know that CPU isnt the fastest around but still, it takes ca 5-10min to generate a Mesh which is pretty slow to my mind. Am i using the wrong options? My mesh is basically a 1° part of a 2 stage turbine rig, so it is a quasi 2D mesh. I sweep the faces and use inflation layers and some mesh face sizings where i need it. Regards |
October 13, 2013, 23:04 |
Petr Jurcicek
Rep Power: 16 |
Hi Peterputer,
I've got similar problem when meshing a geometry using the sweep method for CFX pseudo 2D axisymmetric problem. Is there any other solution to this problem? Could you suggest some other alternative meshers? Thanks; Peter |
October 16, 2013, 08:44 |
vidyanand
Rep Power: 17 |
Yes ANSYS mesher is slow,Please check uncheck ature and proximity
or if it tet mesh use patch independent with incresing number of Cpu |
[ANSYS Meshing] trying to mesh a saloon car in wind-tunnel with Ansys 13.0 Workbench mesher | IvanCFD | ANSYS Meshing & Geometry | 10 | July 8, 2014 16:55 |
Ansys Mesher too slow | semo | ANSYS | 2 | October 13, 2013 23:16 |
[ANSYS Meshing] Ansys mesher problem with multiple reference frame problem -cannot set as interior BC | cfd1980 | ANSYS Meshing & Geometry | 1 | November 22, 2011 13:25 |
Meshing problem with ansys default mesher | wh88 | ANSYS | 5 | October 5, 2011 17:27 |
Question about ANSYS Mesher and Global Min Size Setting | jonny_b | ANSYS Meshing & Geometry | 4 | April 11, 2011 11:05 |
