[GAMBIT] Mesh inside computer box
Old   June 13, 2012, 00:04
Default Mesh inside computer box
reynold
r.sirait is on a distinguished road
Send a message via Yahoo to r.sirait
Greeting everybody,
I have task to compute temperature distribution inside a computer box,
I already made the geometry (I attach it in this post).
What is the best way to mesh the geometry? Since the space heat sink fan is too small, I afraid my computer's memory won't enough
Thanks.
r.sirait is offline   Reply With Quote
Old   June 13, 2012, 00:40
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
use ANSYS ICEPAK http://www.ansys.com/Products/Simula...s/ANSYS+Icepak specially designed for these type of simulations
Far is offline   Reply With Quote
Old   June 13, 2012, 00:56
reynold
Yes Sir I also learn to use Icempak now, and the problem is I already tried to mesh the geometri with conventional way, but then gambit says "error, out of memory", because the geometri is to small compare to the whole computer box
One of my friend suggest that i must make another simulation for the heat sink fan only, to find the heat transfer coeff of the heat sink fan,
Then put simpler geometri to the computer box and use the heat transfer coeff of hsf for the simulation, how it sounds?
Is there any other suggestion?
Old   June 13, 2012, 02:08
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you get "out of memory" because you are trying to mesh your domain on the fly (in one shot).
Since your geometry has small gaps, the mesh has to be fine overthere and then your mesh will ask lots of memory.
But if you decompose (split) your geometry, you will mesh sub-volumes, which will ask less memory
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 13, 2012, 02:50
Far
Sijal
Flexible, Automatic Meshing
ANSYS Icepak software contains advanced meshing algorithms to automatically generate high-quality meshes that represent the true shape of electronic components. Options include hex-dominant, unstructured hexahedral and Cartesian meshing, which enable automatic generation of body-fitted meshes with minimal user intervention. The mesh density can be localized through nonconformal interfaces, which allows inclusion of a variety of component scales within the same electronics cooling model.
While fully automated, ANSYS Icepak contains many mesh controls that allow customization of the meshing parameters to refine the mesh and optimize the trade-off between computational cost and solution accuracy. This meshing flexibility results in the fastest solution times possible without compromising accuracy.
Icepak contains the automatic meshing algorithms. It basically links design modeller, ansys meshing and Fluent
Edit http://www.figes.com.tr/english/ansy...uct/icepak.php
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ANSYS Meshing] avoid to mesh the inside of the blade swiss_zhang ANSYS Meshing & Geometry 1 June 9, 2011 08:37
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
