[ICEM] Meshing adjacent wall geometry and simple ICEM questions
Like Tree2Likes
Old   June 18, 2012, 04:55
AB
BrolY will become famous soon enough
For the quality option, it's obvious that the index control is not the solution.
But for the fact that blocks sometimes disappears when you click "undo", that's obvious it may be the solution.
About the "undo" which doesn't work after you saved your project, it's just an option : Settings -> General -> Clear undo after saving project or geometry
About your quality issue, I have never heard about that kind of matter, so maybe someone else could help here ?
BrolY is offline   Reply With Quote
Old   June 19, 2012, 09:31
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by everdimension View Post
I think it's obvious that index control is not the matter in this case.
I confirmed - the quality of the initial pre-mesh always worsens after I apply boundary conditions to the named surfaces in the output for fluent.
So each time i want to export mesh I have to save my work as a separate project so that i can "damage" it. And if i want to make some corrections - i delete this project and go to the previous one.
Not possible. May be you are also also including some dead mesh
Far is offline   Reply With Quote
Old   June 19, 2012, 11:59
everdimension is on a distinguished road
I am not doing anything with the mesh at that point. All I do is define boundary conditions in the 'output tab'
After that if i want to look at 'pre-mesh' it asks to recompute, i say yes and i get quality bars starting from zero.
everdimension is offline   Reply With Quote
Old   June 19, 2012, 12:05
Far
Sijal
If you have already converted the pre-mesh into unstructured mesh, ICEM should not ask you to recompute unless something has happened intentionality or unintentionally
Old   June 19, 2012, 12:07
Far
Sijal
Or this may be due to mismatch in boundary condition and association of edges to curves. Or may be you have curves in different part and surface in different part.
Old   June 20, 2012, 05:25
AB
once you have convert your mesh into unstructured mesh, you don't anymore to look at the pre-mesh.
if you want to look at the quality of your mesh, go to "edit mesh" -> "display mesh quality".
as Far said, it's weird you need to recompute if you didn't change anything at all ...
conjugate heat transfer, coupled wall, fluent, icem, inflation
ICEM: Projectile Meshing and Modelling Issues gman89 ANSYS 0 May 12, 2011 00:01
Need help on meshing this simple geometry nha1g08 ANSYS Meshing & Geometry 3 March 9, 2011 03:13
[Other] Geometry and Meshing Questions Flaky ANSYS Meshing & Geometry 6 October 8, 2010 02:10
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
Meshing on simple geometry pukiwawa FLUENT 5 August 31, 2008 13:04
