June 14, 2012, 16:51 |
#22 |
I tried the same but i got lot of errors.. ..Pleaseeee tell me the procedure you followed with values...
June 14, 2012, 16:55 |
#23 |
I am really sorry..In that project i didnt convert structured mesh to unstructured. I directly used the structured mesh to create unstructured tetra mesh.
Please delete the mesh and convert the pre mesh to unstructured before creating the tetra mesh.. Sorry again... I think the files got corrupted. If required pls use this https://www.dropbox.com/s/8lv33j8pp4...fliperwing.rar |
July 5, 2012, 11:23 |
#24 |
Maciej
Rep Power: 14 |
sorry for posting here, but I have similiar problems with mesh merging. Maybe you can help? Whenever I make hex mesh, then convert it to unstructered, then i want to make tetra mesh for different part (I set create mesh for only visible parts, and use exisiting mesh from parts with hex unstructered mesh) hex mesh disaapears. Am I doing something wrong? |
July 5, 2012, 11:49 |
#25 |
Ghazlani M. Ali
Rep Power: 29 |
i think when you create your mesh, it re meshes everything like a resetting. What i do is separate the parts by surfaces so i don't lose anything. then that surface will be used for merging.
July 6, 2012, 03:15 |
#26 |
Maciej
Rep Power: 14 |
Yes, these regions are seperated by internal wall. But i think I've managed to do this. After using hexa mesh to create tetra on difeerent region, i just convert pre-mesh to unstructured mesh again, and click 'merge' when icem asks me what to do.
Thanks for your help anyway Cheers |
July 7, 2012, 03:15 |
#27 |
mackr,
1. The merge which icem proposes is not the "merge" which was meant in this thread. 2. what you did was just to create "non conformal mesh" ie mesh nodes are not connected at the interface.they are kind of hanging. 3. after you convert the structured mesh you must be having both the meshes. So to have conformal meshes (ie to join the nodes) go to edit mesh and merge nodes. |
#28 |
Just a small note.. I just found out that, if you use fluent you dont have to merge the meshes. Fluent takes care of non conformal meshes as well.
You just have to define the "interface" in "mesh interfaces" in fluent and it will run normally. Even the size of the structured and unstructured elements at the interface does not matter.. |
curved edge, interface, merge mesh, mesh control, sinusoidal leading edges |
[snappyHexMesh] Irregular mesh generation for simple box geometry | ajl42 | OpenFOAM Meshing & Mesh Conversion | 0 | March 7, 2011 17:04 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
