June 4, 2012, 17:28 |
Part for Inlet or Outlet
yang
Rep Power: 14 |
I met a problem about Part for Inlet or Outlet using ICEM. I create a surface called Inlet and produce a Part of this Inlet based on the surface. After meshing, I import the mesh in CFX-Pre, but there is no this Inlet option in CFX-Pre, there are only all kinds of Walls option.
Who could help me deal with this problem? I guess whether I need select the 4 curves of the Inlet surface as the Part also (except the surface of Inlet)? Many thanks in advance! |
June 4, 2012, 18:24 |
Ghazlani M. Ali
Rep Power: 29 |
is your geometry in 3d or 2d ? did you use blocking, make sure associations are done. i usually create parts first then start meshing. Also may be this post can help solve the problem:
http://www.cfd-online.com/Forums/ans...em-fluent.html |
June 4, 2012, 18:48 |
#3 | |
yang
Rep Power: 14 |
I guess whether I need select the 4 curves of the Inlet surface as the Part also (except the surface of Inlet)? I only create a Surface called Inlet and produce a Part of this Inlet based on the surface not including 4 curves of the Surface. Many thanks! |
June 5, 2012, 08:28 |
No Inlet option, but wall only?
Did you define a new boundary, and select the target "Inlet" surface as the inelt? 2D mesh, line element, is not needed to define a boundary, surface is enough. |
June 5, 2012, 08:48 |
#5 | |
yang
Rep Power: 14 |
However, I mean I only create a Surface as Inlet and then produce a Part called/as Inlet based on the surface in ICEM not in CFX-Pre. Actually, I find the solution. Since my Body doesn't include the whole space. So we can't see Inlet option in CFX-Pre. Many thanks also! |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 18:16 |
Pressure outlet boundary condition | fluent_newbie | FLUENT | 0 | December 2, 2011 00:51 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 11:09 |
Outlet Problems | Cyberholmes | OpenFOAM | 5 | August 4, 2011 12:31 |
large vortex on outlet when gravity accounted for | Alejandra Menchaca | Phoenics | 0 | March 3, 2009 20:53 |
