[ICEM] ICEM surface trim and blocking projection
Old   May 20, 2012, 11:02
Default ICEM surface trim and blocking projection
Felipe Mendes
Felipe Mendes is on a distinguished road
Hello my friends,
I've been doing a script in ICEM to produce a mesh based on a given geometry of guide vanes and stay vanes of a pump turbine and some parameters of the domain. It's a "almost 2D" domain, in order to simulate a 2D in CFX.
I've been facing some problems that I don't know how to overcome:
1) To create the surface, as it has a complicated geometry I've been using the "trim surface with curve". The script was done and working perfectly, and without changing anything, it stoped working this trim operation. I don't know why.. the lines and the plane are in the same plane (Z=0), and the lines form a closed perimeter.
2) When I create the 2D blocking, one of the sides of the blocking square that should appear "sometimes" is on the infinity. The most strange is that if I run the script a couple of times, the error may appear in a randomic way.
Does anyone has faced something like this, or might have a clue of what is happening?
Thanks in advance!
Felipe Mendes is offline   Reply With Quote
Old   May 20, 2012, 11:13
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
We can help you, if you can provide more information (pics, files e.g. tin, blk and script)
Far is offline   Reply With Quote
Old   May 20, 2012, 11:54
Felipe Mendes
I'm uploading here the geometry .stp and the replay script. If you put both of them on the same folder (and change the paths on the replay script to this folder.. usually on the beggining and end of the script) you can run it, but it will only run well on a Linux machine!
The GV_domain has the problem on the blocking, while the GV_domain_bkp20.05 has a problem on the trim operation (which is my main problem).
Thanks a lot!!
Old   May 21, 2012, 04:08
Felipe Mendes
Seems that the problem on the trim plane is that when I cut the circles to form the inlet and outlet lines of the domain (that are used to trim), there is a small gap that is formed (~0.01). Is there anywhere I can configure the allowed gap? Or somewhere I can merge points that are near?
Thanks!
blocking, icemcfd, script, trim
