[GAMBIT] Meshing two cylinders in a larger cylinder
Old   May 15, 2012, 13:28
Default Meshing two cylinders in a larger cylinder
Christopher Hershey
Hershey is on a distinguished road
How would one treat the inner cylinders' wall thickness. I am not interested in their properties, just the flow around them. Do I still have to mesh the walls?
Hershey is offline   Reply With Quote
Old   May 16, 2012, 01:32
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
just forget the thickness and mesh the wall which is in contact with your fluid
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 16, 2012, 08:50
Christopher Hershey
Thank you for your reply -mAx-. I have ended up doing what you said. I seem to be running into the problem with GAMBIT creating default walls in my mesh. For instance, I have split two volumes to allow for the meshing; one small cylinder going into a large cylinder. However, the meshing is fine but when I export the project to a mesh, it creates a wall in between the two volumes which should normally be one continuous fluid.
I am not sure the difference in connecting faces/volumes vs. hard-linking the meshes.
Any ideas?
Old   May 16, 2012, 09:28
-mAx-'s Avatar
Maxime Perelli
any pictures?
If small cylinder is completly in the bigger cylinder, then you need to split the gigger volume with the smallest. And you delete the smaller cylinder.
Or you can also substract the biggest with smaller.
hard linking is something else.
With picture it will be more clear
Old   May 16, 2012, 10:14
Christopher Hershey
For simplicity, I am attaching a picture with only a single small cylinder inside a larger cylinder. It meshes correctly, however the faces that appear in blue are defaulted as walls by GAMBIT. This is a problem I normally have. I connected the faces that are in the middle of the smaller cylinder and that got rid of the default wall. I am not allowed to connect the faces that are shown in blue though. Just to clarify, the large non-donut face comes from the large upper portion of the cylinder, while the donut face comes from the lower portion of the large cylinder.
Flow is supposed to rise out of the bottom of the small cylinder and out the top of the large cylinder with the freedom to fall down into the bottom of the cylinder.
cylinder, gambit, hollow, mesh, wall
meshing on cylinder fails ICEM potac ANSYS Meshing & Geometry 0 October 25, 2011 06:21
2D planar cylinder meshing problem saisanthoshm88 ANSYS Meshing & Geometry 15 December 27, 2010 12:14
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 15:37
[blockMesh] Meshing inside a cylinder so that the edges contain more cells than the center Bertrand OpenFOAM Meshing & Mesh Conversion 1 April 13, 2010 05:46
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
