[GAMBIT] problem with importing geometry in Gambit
Like Tree4Likes
Old   May 9, 2012, 05:10
Default problem with importing geometry in Gambit
Bahar
bahar is on a distinguished road
Hello everybody,
I am new to Gambit and I would like to import a 3D drawing from Solidworks into Gambit, I tried ACIS,Parasolid and STEP format files, but nothing could be shown in Gambit!
what would be the problem?
Thank you in advance,
bahar.
bahar is offline   Reply With Quote
Old   May 9, 2012, 06:02
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
any error or warning in the transcript window?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 9, 2012, 12:33
Default Re:problem with importing geometry in Gambit
Bahar
Actually not!
I've heard somewhat about cleaning up the solid file,what does it mean? may it be related to my problem?
Thanks for your attention,
bahar.
Old   May 10, 2012, 02:21
-mAx-'s Avatar
Maxime Perelli
Then you should get any info like:
Imported: 1 ACIS BODY(s), 0 FACE(s), 0 EDGE(s), 0 VERTEX(es)
Do yo get 0 body, 0 face and 0 vertex?
Once you imported your geometry, try to delete any vertex, edge, surface or volume.
By clicking on the fat black arrow (right next to the yellow rectangle), you will get the list of entities which are in your session.
Old   May 10, 2012, 08:37
Bahar
Dear mAx, thanks for your attention!
I've found such a command by clicking on the fat black arrow: ''save file is from a later version of Acis''
I'm working with Solid 2012 and using Gambit 2.3.16. what should I do?
bahar.
Old   May 10, 2012, 08:47
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi bahar,
is your license OK? I have a same problem with .CATPART. I found that my license is not perfect.
adambarfi is offline   Reply With Quote
Old   May 10, 2012, 14:40
ali
dearali911 is on a distinguished road
Send a message via Skype™ to dearali911
hi every one
i also have this kind of problem.gambit actually fails to import any type (igs,acis,etc) file.showing license error. sometime 0body.0 vortex,0 alla balla
dearali911 is offline   Reply With Quote
Old   May 12, 2012, 12:02
Bahar
Hi everyone,
adambarfi, It seems that the licence works correctly. I received such a message in Gambit: ''save file is from a later version of Acis''
dearali911, I do not receive this message. Maybe adambarfi could help you!
Old   May 14, 2012, 02:06
-mAx-'s Avatar
Maxime Perelli
So I imported your step file, and I get a cylinder with ř1.73 and height 1
Old   May 14, 2012, 09:14
Bahar
Wow! Thank for good news!
Which version of Gambit do you use mAx?
Old   May 14, 2012, 09:21
-mAx-'s Avatar
Maxime Perelli
2.4.6
But if you wanted to import such a simple geometry... you can build it direct in gambit, by creating a cylinder
Old   May 16, 2012, 03:39
Bahar
Thank you dear mAx
I finally imported the geometry in Gambit.
But there's another question! In the ACIS file only bodies are known for Gambit.
What is the best way to create faces, edges and etc? Is it accurate using points?
Old   May 16, 2012, 03:44
-mAx-'s Avatar
Maxime Perelli
it depends on what you want to build
You can build simple volumes directly (cylinder, sphere, torus, rectangle, etc...)
bahar likes this.
Old   May 16, 2012, 06:36
Bahar
My final geometry is a helical blade, So it is not easy to create in Gambit.
What should I do?
Old   May 16, 2012, 06:38
-mAx-'s Avatar
Maxime Perelli
post a picture of what you want to build in gambit
Else build it in a cad package and export the final volume as STEP file in gambit
Old   May 16, 2012, 06:55
Bahar
It is a vertical axis wind turbine, I understand that Gambit has detected faces,edges and etc by getting information.
The next question is about how to mesh it?
Thank you dear mAx for your helps
Old   May 16, 2012, 06:59
-mAx-'s Avatar
Maxime Perelli
it sounds you have already build it in gambit, don't you?
is it your final geometry you want to compute? I mean you need fluid flowing around the blades?
Old   May 16, 2012, 07:13
Bahar
Yes, that's right.
I need flow around blades and I do not know how to mesh such a complex geometry!
Old   May 16, 2012, 08:24
-mAx-'s Avatar
Maxime Perelli
do you have surfaces or volumes topology?
In your case you only need to create your outer domain (lets say a box), and then you substract the box with your blades.
The result will be the box with blades as hollow.
Old   May 18, 2012, 01:57
masood
masoodina is on a distinguished road
hi bahar . i had the same problems months ago. u d better export the file in sldworx as igs file . then import igs file in gambit activating naitve choice .
now you have the faces ready . just convert the faces to real faces and create volumes using the faces .
according to your geometry you , i think you cant have a very good mesh in gambit . maybe use quad/tri mesh for faces then tgrid mesh for volumes .
masoodina is offline   Reply With Quote
Gambit - Mesh Problem for a complex 3D geometry Nelson FLUENT 3 May 28, 2012 07:57
[GAMBIT] Importing Coil from AutoCAD Inventor to Gambit kolapoasafa ANSYS Meshing & Geometry 3 July 14, 2011 08:26
problem importing solidworks file into gambit mzack1104 ANSYS Meshing & Geometry 4 September 17, 2009 12:27
Problem of importing the geometry Dany CFX 4 March 28, 2003 10:49
Creating geometry & meshing using Gambit Ray FLUENT 3 August 1, 2000 04:30
