[GAMBIT] problem with importing geometry in Gambit |
May 18, 2012, 02:04 |
meshing the wind turbine
#21 |
masood
Rep Power: 14 |
sry . i think actually you must not mesh the wings . you must a create a big volume (like cube or a cylinder ) around the wings so that fluent will solve the flow around the wings . then make the volume pressure_far_field in boundary condition and the wings wall .
May 19, 2012, 08:25 |
#22 |
Bahar
Rep Power: 14 |
Dear mAx, I have volume topology.Thank for your help
Hi masoodina, Thank for your attention. I've get surfaces and edges from volumes now meshing is my problem. |
June 11, 2012, 11:53 |
#23 |
Bahar
Rep Power: 14 |
Thank you very much dear mAx, my problem has resolved finally!
December 1, 2014, 06:24 |
#24 |
sohit
Rep Power: 12 |
i am trying to import a screw-barrel model which is designed in solidworks, and have the problem at the time of file importing iges,acis and step format in gambit. in the acis format, I received a message in Gambit: ''save file is from a later version of Acis and in the rest of format it is showing the license error . can anyone tell how to get rid from this problem? it is very urgent. |
December 1, 2014, 06:47 |
#25 |
Maxime Perelli
Rep Power: 41 |
what is the exact error message?
for importing geometry you need a special key in the license file
In memory of my friend Hervé: CFD engineer & freerider |
December 6, 2014, 04:52 |
#26 |
Bahar
Rep Power: 14 |
The source of this problem is incompatibility of the Gambit version and Solidworks.
Save as your IGS or ACIS file in a lower version like 9 or 10 and then reload it in the Gambit. Bahar |
December 11, 2014, 13:50 |
#27 |
sohit
Rep Power: 12 |
Thank you mAx and Bahar. I followed your suggestion and it works in ACIS version 12.
but again I am facing another problem during the meshing. Can any one tell, how to mesh a mini screw in gambit?. I need to mesh this by using hexagonal volume mesh but due to the highly skew surface it is not meshing and also it is not recognizing some faces of screw during mesh and when I am going for quadrilateral mesh, mesh is happening but on exporting this file in ansys polyflow it is neither showing the boundaries nor the screw geometry. |
December 12, 2014, 01:57 |
#28 |
Maxime Perelli
Rep Power: 41 |
display your geometry and also the surface mesh which gives you trouble
Gambit - Mesh Problem for a complex 3D geometry | Nelson | FLUENT | 3 | May 28, 2012 07:57 |
[GAMBIT] Importing Coil from AutoCAD Inventor to Gambit | kolapoasafa | ANSYS Meshing & Geometry | 3 | July 14, 2011 08:26 |
problem importing solidworks file into gambit | mzack1104 | ANSYS Meshing & Geometry | 4 | September 17, 2009 12:27 |
Problem of importing the geometry | Dany | CFX | 4 | March 28, 2003 10:49 |
Creating geometry & meshing using Gambit | Ray | FLUENT | 3 | August 1, 2000 04:30 |
