[ICEM] Interior surface
Old   April 26, 2012, 16:19
Default Interior surface
Italy
Mario22 is on a distinguished road
Hi, I'm a student and I'm doing my thesis with ICEM.
I have a 3D mesh and I need to put same interior surfaces in the volume for the post-processing.
The problem is that ICEM doesn't mesh the surfaces, due to this Fluent doesn't recognize them. I tried to fix it in this way:
1) I selected, from the part setup menu, the "int. wall" option for the part of the new surfaces, but it makes error during the meshing with Smooth.
2) From the same menu I selected "split wall", but it makes errors too.
As you can see right now I'm shooting in the dark.
Please help me.
Excuse me for my bad English, I've to improve it...
Mario22 is offline   Reply With Quote
Old   April 27, 2012, 09:29
jeevan kumar
jeevankumarb is on a distinguished road
HEllo Mario,
Usually if you select internal wall option it will mesh the internal surface. But make sure that there is a material point on either side of the internal surface. If you can post some images it will help in understanding your problem more clearly.
Regards
Jeevan
jeevankumarb is offline   Reply With Quote
Old   May 2, 2012, 14:49
Italy
I made a mistake in the creation of the surfaces. The two volume weren't completely separated so ICEM gave error.
Thank you so much for your response.
Goodbye
int. wall, interior faces
