April 26, 2012, 11:32 |
Equal mesh for periodic BC
Felice
Rep Power: 16 |
Hi all,
I have a cylinder and I want to simulate only a little part of it, for example 36°! In fluent I have to set mesh>modify-zones>make-periodic. In order to do that, I need that the two sides have the same mesh, it's right? How can I set that condition in Ansys mesher? Regards F |
April 26, 2012, 11:39 |
Rep Power: 15 |
Use "Match Control" in Meshing and select 2 faces of your periodic BCs. Also if it is rotational periodicity change "Transformation" to "Cyclic".
April 26, 2012, 11:43 |
#3 | |
Felice
Rep Power: 16 |
Thanks a lot! F |
December 1, 2015, 13:09 |
identical surface mesh
Rep Power: 11 |
Hi felicemastronzo, I have a very similar problem to yours, my geometry is not a cylinder but a parallelepiped with four circular holes. I'd like to have two identical surface meshes, the upper side and the lower side.
How did you solve your problem? Thanks you so much G |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 11:40 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 05:49 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
