[DesignModeler] Creating Two Separate Bodies in Design Modeller
Like Tree9Likes
Old   July 28, 2015, 19:27
Kapi is on a distinguished road
Hi sazeda,
try Boolean to create subtract bodies and then preserve them.
Boolean
Operation: Subtract
Preserve tool bodies?: Yes
Cheers
KAPI
azna and sazeda like this.
Kapi is offline   Reply With Quote
Old   August 18, 2015, 20:00
Default Symmetry/mirror feature in Design modeler workbench
  #22
Joe
enayath is on a distinguished road
Hello folks,
I created a 3D geometry. I would like to use symmtery/mirror application as I draw half of my domain. It seems this feature should be available in design modeler as it is a basic one but can not find it. Any idea would be appreciated!
enayath is offline   Reply With Quote
Old   August 18, 2015, 22:18
Hi Hooman,
You dont need to create other half.
Run your simulation on current geometry just give Boundary condition of "Symmetry" on the symmetry surface.
Cheers
KAPI
Old   August 18, 2015, 22:28
Joe
Dear Kapi,
Thanks for the reply. Basically I want to use it inside a full 3d geometry and the figure I showed, is about 1/9 of the geometry. I would be grateful if you could still help me to mirror the geometry to both x and y planes.
Thanks!
Old   August 19, 2015, 12:06
Joe
Kapa,
I found it. I needed to use "mirror" from body transformation.
In order to copy the geometry you need to use "pattern".
Old   August 19, 2015, 13:24
azna
azna is on a distinguished road
Originally Posted by enayath View Post
Dear Kapi,
Thanks!
If you just want to see the results after running the simulation, you can use mirror option in fluent or in the CFD post to see the full geometry.
azna is offline   Reply With Quote
Old   August 19, 2015, 13:26
Joe
Azna,
No ...it is different...thanks for the time though...I posted the correct answer above.
Best
Old   September 10, 2015, 09:27
SJSW is on a distinguished road
"Add Frozen" and "Form New Part" is OK for a combination of solid and fluid bodies.
The interfaces would become "Coupled" automatically.
However, if the two bodies are of the same type (fluid or solid) and you need multiple cell zones, these operations would not work.
Following the tutorial found in the official site, I tried "Mesh control," but it said
writing contact_region-src (type interface) (mixture) ... Done.
writing contact_region-trg (type interface) (mixture) ... Done.
writing sliding-interface contact_region ... Done
Does it matter? and what's the difference? I don't know.
Could someone help?
SJSW is offline   Reply With Quote
Old   September 10, 2015, 13:30
Antanas is on a distinguished road
Could someone help?
"Add Frozen" just prevents intersected bodies from union. "Form New Part" just makes multibody part from bodies in order to create conformal mesh in AM. Designation of bodies as "Fluid" & "Solid" is mainly for visualisation purpose, fluid makes body transparent. I don't think it affects anything else.
Antanas is offline   Reply With Quote
Old   June 13, 2016, 06:37
Smile Design Modular
  #30
Ajaykumar
AeroAjaykumar is on a distinguished road
How to create duplicate in ANSYS 16.2 workbench?
AeroAjaykumar is offline   Reply With Quote
Old   June 13, 2016, 10:36
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Please start a new thread, explain what you want to do, and include screenshot
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 13, 2016, 06:50
shravan2650 is on a distinguished road
You can also use Boolean function
- Create > Boolean : Select subtract , select the target and tool bodies; For the option preserve tool bodies -select 'yes'
Doing this will give you 2 separate bodies
shravan2650 is offline   Reply With Quote
Old   January 25, 2018, 10:42
et.one is on a distinguished road
I have the same problem. I would like to create different parts ( different connected volume) but all being part of one body. I have not found anything on the forum.
Please Can anyone help me or tell me where I can find the answer?
thank you very much in advance
et.one is offline   Reply With Quote
Old   January 25, 2018, 12:20
Joe
I am not sure what you meant.
You can have different bodies in one part n order to make a conformal mesh and let FLUENT take care of the interfaces automatically. If you make different parts, you will end up in a non-conformal mesh and you need to assign the interfaces manually.
Best
Old   January 25, 2018, 12:27
Hi enayath,
thanks for your reply. I have got the geometry that I have attached. I was able to create a single body with different parts which should be connected. I don't have any problem if I want to create a simple tetrahedral mesh. However if I want to create a hexahedral mesh the mesh software keeps giving me an error and I do not understand why. Please can you help me ?
Thanks
Old   January 25, 2018, 12:57
Joe
I can not see the attachment.
Old   January 25, 2018, 13:30
sorry now you should have access
https://ibb.co/ioMWrw
Old   January 25, 2018, 13:34
Joe
You need to play with the "settings". Try Multizone instead of automatic and set everything to fine instead of coarse. You may also need to decrease the min length or face size in the settings.
Old   June 6, 2018, 18:31
kailash
kailash007 is on a distinguished road
Originally Posted by vivekananda View Post
ya. if you do with frozen, you will have two independent body. But if you use slice option you will have two separate bodies. The interface will have src, trg and several wall regions. If you add to bodies using form new part, you will have interace common to both bodies. But you will have interface regions with
wall-part-fluid, wall-part-solid, wall-part-fluid-part-solid, and shadow regions.
Does anyone know why this happens? How to create common interface?
Yes i am also facing the same issue. Anyone know how to solve this ?
kailash007 is offline   Reply With Quote
Design modeller ease to use taw CFX 4 May 2, 2011 16:51
[Other] Import autocad into Design modeller lcea ANSYS Meshing & Geometry 1 December 1, 2010 14:15
surface bodies from design modeler to CFX chisa CFX 0 June 9, 2010 12:36
creating a solid body in Design Modeller Dan CFX 0 May 24, 2004 12:59
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
