[ICEM] 2D Hexa meshing
Old   April 21, 2012, 22:31
Default 2D Hexa meshing
Osama
osamaghani is on a distinguished road
I am trying to mesh a 2D car geometry in ICEM..I have followed the 2D hexa Blocking tutorial included in ICEM.
The problem is..I need to define certain parts of the car separately...but when I open the mesh in FLUENT, it does not give me all the parts...rather it combines the entire geometry in one part
Any ideas???
osamaghani is offline   Reply With Quote
Old   April 22, 2012, 02:19
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Then do not select all curves and edges while making edge-to-curve association. Rather select the separate boundary curve to corresponding edge.
http://www.cfd-online.com/Forums/ans...em-fluent.html
Far is offline   Reply With Quote
Old   April 22, 2012, 15:24
Osama
Hi Far,
I tried to do that but ICEM did not allow me. whenever I do the associations of edge to curve...it always selects the entire car geometry rather that single curves...plus how can I decide which edge to associate to what curve??
I am having a lot of issues with 2D hexa meshing..below is a list of my queries..I appreciate your effort..Hi Simon
I have successfully followed the ICEM 2D hexa tutorial...but
I have a few questions/issues about 2D meshing..
1. what is the best strategy for 2D meshing? Blocking or Direct unstructured?
2. what is the best blocking topology for car geometry?
3. When I do blocking and then open mesh in fluent, all the parts on my car geometry are combined to one part...underbody(2D-line/curve)
4. In any case, Blocking or Direct unstructured, I can not see any surface in FLUENT...all I see is mesh elements even though I create surface in ICEM
5. When I do direct unstructured, only Patch independent method works...all other methods fail...either ICEM hangs or ends in an error...
I make surface for fluid in ICEN..my IGES is curves for tunnel and car geometry...
I can give you some more information or upload my domain if you can take a look at it...
Please help me...I appreciate your effort
Thanks
osama
Old   April 22, 2012, 15:51
Far
Sijal
attach files
Old   April 22, 2012, 15:54
Osama
can I email you the files on turboenginner@gmail.com??
Old   April 22, 2012, 15:57
Far
Sijal
ya, please.
Old   April 22, 2012, 16:26
Osama
check your email...
Old   April 22, 2012, 19:03
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
Hi osama,
Check out section 4.2.3 or page number 123 in the link
http://mecanica.eafit.edu.co/~sorrego/icemtutorial.pdf
. This ebook will be helpful in many ways..
Ananthakrishnan is offline   Reply With Quote
Old   April 22, 2012, 19:40
Default First try
Far
Sijal
I have tried and created some initial blocking. Files sent through email.
Please let me know, if pics need to be removed from the forum.
Old   April 23, 2012, 06:58
AB
BrolY will become famous soon enough
I don't know a lot about FLUENT, but I read that Fluent needs curves for a 2D mesh.
So 1) do a bluid topology of your geometry.
2) create parts (inlet, outlet, etc...) and puts curves and points on it.
Those parts will be your boundary in FLUENT.
3) if you use blocking, always associate the curves to the edges, especially those which are used for the BOCOS.
The patch dependent didn't work because you need a very good topology -> build topology is compulsory for this method.
Also, post some pictures with the parts you defined in ICEM, it would help.
BrolY is offline   Reply With Quote
Old   April 23, 2012, 16:23
Osama
Hi alex,
thanks for the info! that explains my problem about patch dependent method.
I will keep your advice in mind next time when I post...Far helped me with blocking so that problem is also resolved!
2d hexa mesh, 2d meshing
[ICEM] Hexa meshing of impeller and diffuser assembly Nitin Dewangan ANSYS Meshing & Geometry 14 September 13, 2016 10:41
[ICEM] Hexa dominant meshing Pat84 ANSYS Meshing & Geometry 19 December 2, 2015 18:20
Wind tunnel hexa meshing in ICEM CFD 12.1 matheusguzella ANSYS Meshing & Geometry 1 March 14, 2011 17:14
Hexa Block meshes in ANSYS Meshing? siw ANSYS Meshing & Geometry 3 July 31, 2009 11:40
Hexa meshing or Tetra meshing??? NITIN DEWANGAN CFX 5 August 5, 2008 10:59
