parabolicVelocity as boundary condition in OF-1.7? |
February 25, 2011, 09:32 |
Rep Power: 16 |
Dear All,
as to OpenFOAM version 1.5 there was a boundary condition called 'parabolicVelocity' where parabolic velocity-profiles were applied to patches. So my question is: Is there any comparable patch-/boundarycondition that can be used? Or: I got another computation where i can see the parabolic profile in Paraview - how can i export it and use it as inlet-BC for another case? With best regards, CST |
March 1, 2011, 03:21 |
Alan Russell
Rep Power: 17 |
CST,
One way to create a parabolic inlet velocity profile is in the tutorials. Look through tutorials/incompressible/simpleFoam/pitzDailyExptInlet. The profile is in the constant/boundaryData/inlet directory. You set up the points file to specify points and the /0/U to set the velocity at each point. I use this method frequently - it's easy to set up. If this doesn't work, you can search the forum for velocity profiles or inlet profiles. Good luck, Alan |
March 2, 2011, 04:30 |
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
Rep Power: 17 |
CST,
Another possibility is to use the groovy boundary conditions see http://openfoamwiki.net/index.php/Contrib_groovyBC Something like this should make the trick in 2D: inlet { type groovyBC; variables "yp=pts().y;minY=min(yp);maxY=max(yp);para=-(maxY-pos().y)*(pos().y-minY)/(0.25*pow(maxY-minY,2))*normal();"; valueExpression "10*para"; value uniform (10 0 0); } Best regards, Frederic
Frederic Collonval Technische Universität München Thermodynamics Dpt. |
March 20, 2012, 12:51 |
#4 | |
Goutam Saha
Rep Power: 14 |
I have simple pipe flow case, length is 1.2 m and radius is = 0.02595 m. I want to generate the the points file for my case. U(x) = 2U_0 [ 1 - (x/r)^2 ] x and y varies from -0.02595 to -0.02595 and z varies from 0 to 1.2. Could you give me some suggessions about points file and velocity file in he constant/boundaryData/inlet directory. Thanks |
March 22, 2013, 10:51 |
starter
Rep Power: 16 |
Alan
Do you have any tutorial for fixing points and velocity. I am a beginner in OpenFoam who is trying to do his MS in CFD. Can you give me a few tips as i have to use 1/7th power law for turbulent flow in my pipe. Regards |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 13:26 |
Transient outlet boundary condition problem | jwillie2000 | CFX | 1 | December 7, 2009 18:07 |
Axis Boundary Condition..what is it? | CFDtoy | FLUENT | 6 | February 13, 2007 06:51 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 12:44 |
How to resolve boundary condition problem? | sam | FLUENT | 2 | July 20, 2003 03:19 |
