makeCellSets.setSet Usage
Like Tree2Likes
  • 1 Post By rob3rt
  • 1 Post By m.nichols19
Old   June 10, 2010, 16:43
Default makeCellSets.setSet Usage
m.nichols19 is on a distinguished road
I am attempting to model the conjugate heat transfer of water flowing through a steel pipe using the chtMultiRegionFoam solver. I successfully ran the chtMultiRegionFoam tutorial, so I have a relatively good grasp on the solver; however, I am having issues with the makeCellSets.setSet file that accompanies the solver.
From what I understand, makeCellSets creates rectangular-prism regions in the mesh using the boxToCell command. For my problem, I need a cylindrical region through the center of the mesh for the water to flow through.
Is there a command other than boxToCell that will allow me to create this cylindrical region in makeCellSets? If not, is there a way other than makeCellSets to create regions in a mesh that will work with the chtMultiRegionFoam solver?
Here is my simple code for the makeCellSets.setSet file:
cellSet water new boxToCell (80 80 0)(-80 -80 10)
cellSet tube clear
cellSet tube add cellToCell water
cellSet tube invert
Thanks in advance!
-Matt
m.nichols19 is offline   Reply With Quote
Old   June 11, 2010, 00:52
Robert
rob3rt is on a distinguished road
Hi Matt,
Try using the surfaceToCell. Further instructions can be found in the cellSetDict file under applications/utilities/mesh/manipulations/
aromali likes this.
rob3rt is offline   Reply With Quote
Old   June 11, 2010, 12:26
Thank you for your reply.
I used the cylinderToCell command in cellSetDict and it solved my problem!
best regards,
Matt
Ramzy1990 likes this.
FloWorks and CPU usage? cvp_dk FloEFD, FloWorks & FloTHERM 6 June 20, 2011 09:57
OpenFOAM Solver/BC usage description murrayjc OpenFOAM 3 August 25, 2009 05:48
Swap usage on parallel run nikhilesh OpenFOAM Running, Solving & CFD 0 April 30, 2009 10:50
Swap usage on parallel run nikhilesh OpenFOAM Bugs 1 April 30, 2009 05:42
How to increase memory usage by fluent Anastasios Georgoulas FLUENT 2 December 29, 2008 06:41
