Incompressible LES tutorial (oodles) - time averaged statistics
Like Tree4Likes
  • 2 Post By fs82
  • 2 Post By fs82
Old   July 8, 2009, 10:45
Default Incompressible LES tutorial (oodles) - time averaged statistics
Bernard Esterhuyse
bernarde is on a distinguished road
Good day
I have completed the Incompressible LES tutorial (oodles pitzDaily). Viewing the results in paraFoam gives me the field values at discrete time steps throughout the simulation.
However, I would like to view the average over say the last 100 steps, to view the statistics of the solution. Is there a way I can do this in paraFoam?
Also, how is convergence judged in this example? Normally I judge conversion in a LES by looking at velocity at a probe point and observing the instance when this velocity starts fluctuating around a constant value.
Any help on this greatly appreciated.
Regards
bernarde is offline   Reply With Quote
Old   July 10, 2009, 05:47
Dr. Fabian Schlegel
fs82 is on a distinguished road
put this in your controlDict for averaging:
functions
fieldAverage1
// Type of functionObject
type fieldAverage;
// Where to load it from (if not already in solver)
functionObjectLibs ("libfieldAverage.so");
// Fields to be averaged - runTime modifiable
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
If you want to probe points during calculation, there exists another funktion you can turn on in your controlDict:
probes1
type probes;
functionObjectLibs ("libsampling.so");
// Locations to be probed. runTime modifiable!
probeLocations
(0.0 0.0 0.0)
// Fields to be probed. runTime modifiable!
fields
U
p
arvindpj and amolrajan like this.
fs82 is offline   Reply With Quote
Old   July 10, 2009, 06:05
Bernard Esterhuyse
Thanks. I figured out how to do this. The problem I have was more to view the averaged values in paraView. I found that you required the UMean and PMean files in the /0 folder to enable paraFoam to load them into the postprocessor.
Old   July 10, 2009, 06:25
Dr. Fabian Schlegel
I do not using paraview. I prefer Tecplot, but if you turn on the fieldAverage1 function I mentioned above, you will get at every time step you write out during a run a Umean, Pmean UprimeToMean and PprimeToMean file. I am sure that paraview will load Umean and Pmean, because Tecplot does that to (to be more acurate: the foamToTecplot converter treat this fields). May be paraview will get problems with the symmetic tensor field UPrimeToMean, like the foamToTecplot converter, but I dont think so.
Old   July 10, 2009, 07:40
Leonardo Giampani Morita
leonardo.morita is on a distinguished road
Once your case is finished, I don't think it's possible to access averages if you didn't turn on fieldAverage function during runtime...neither it is possible to do an averaging like you said, over a specific period of time.
leonardo.morita is offline   Reply With Quote
Old   July 10, 2009, 08:01
Bernard Esterhuyse
Yes, I understand that you need to turn on averaging if you require this for your postprocessing. However, it must be possible to start averaging only after a certain time, say once you have reached psudo-convergence.
Old   July 10, 2009, 08:37
Sure, you can follow a variable with probes and once you judge it has "converged", you go to the controlDict and change "off" to "on". So that averaging will start at that time. Then you can check averaging time in the file <time>/uniform/fieldAveragingProperties.
One important thing to know is that if you change off/on once again, averaging will restart.
Old   July 10, 2009, 08:49
Bernard Esterhuyse
Thanks, this is what I was looking for, will give it a try. How do you monitor the probe variables - do you make use of paraFoam, or do you just view the values in the console? It would be ideal to plot them.
Old   July 10, 2009, 08:54
Since a text file is created, I open it with excel, for example, and plot data.
Hint: try to follow more than one point, at "strategic" positions, in order to make sure (or almost) a "steady-state" has been reached.
Old   July 10, 2009, 09:03
Bernard Esterhuyse
Thanks man, I'll try the excel method. I agree, more than one point is better. Still, it's sometimes hard to be certain if a "steady state" has really been reached.
Old   July 13, 2009, 07:39
Dr. Fabian Schlegel
Allright, it seems to me your problem is solved. OpenFoam reread the controlDict every timestep, if you have set runTimeModifiable to yes. So you can start averaging by switching between on/off. I prefer to comment out the fieldAverage1-function.
Old   August 26, 2016, 15:57
Default time average velocity calculation LES openfoam
  #12
sudhakar singh
Sud09463 is on a distinguished road
Hi fs82
i am using OF3.0. when I am putting fieldAverage in controlDict file, it is showing the following error:
--> FOAM FATAL ERROR:
Unknown function type fieldAverage
Valid functions are :
4
patchProbes
probes
sets
surfaces
How i can calculate average velocity using paraFoam in OF3.0?? I am new to openfoam, please help
Sud09463 is offline   Reply With Quote
Old   August 29, 2016, 03:40
Dr. Fabian Schlegel
Please check if there is a functionOpnject available in
$FOAM_SRC/postProcessing/functionObjects/field/fieldAverage
You will find some piece of code an an example controlDict how to use this fieldAverage functionObject. Furthermore, you can do a "grep -R fieldAverage" on the tutorials directory and find an tutorial case using the fieldAverage functionObject.
amolrajan and sourav90 like this.
Old   August 29, 2016, 08:26
Default fieldAveraging OF3.0
  #14
sudhakar singh
Hello fs82,
thanku 4 quick response. fieldAverage is there in OF3.0 also. but i have one more doubt that, the Umean we are calculating using fieldaverage is time average velocity field or something else?
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 04:32
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow harishg OpenFOAM Bugs 5 December 2, 2008 19:18
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
CFL number and time accuracy for LES Li Yang Main CFD Forum 2 August 1, 2002 07:11
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 15:20
