References for the limitedLinear scheme
Like Tree1Likes
  • 1 Post By tsimon
Old   March 13, 2006, 11:27
Default Hello, where can I find refer
Alberto Passalacqua
where can I find references for the limitedLinear scheme to cite in a paper?
Thanks in advance,
Alberto
Alberto Passalacqua
Old   March 13, 2006, 14:04
Default There is no printed reference
Mattijs Janssens
mattijs is on a distinguished road
There is no printed reference but it is Henry's application of the Sweby limiter to central differencing.
mattijs is offline   Reply With Quote
Old   March 13, 2006, 18:57
Default Thanks Mattijs. Alberto
Alberto Passalacqua
Thanks Mattijs.
Alberto
Alberto Passalacqua
Old   September 7, 2006, 10:42
Default After looking into the code I
Steffen Jahnke
steja is on a distinguished road
After looking into the code I found in limitedLinear.H:
return max(min(twor, 1), 0);
with "twor" beeing equal to 2*r for default setup, e.g. "div(phi,B) Gauss limitedLinear 1;".
For me this limiter looks very similar to the minmod limiter instead of the factor 2:
minmod: return max(min(r,1),0);
The Sweby limiter reads max(0,max(min(beta*r,1),min(beta,r))).
I wondering why this modified limiter is used because due to the factor 2 it lies on the opposite limit (lower left) compared to the minmod in the Sweby diagram.
steja is offline   Reply With Quote
Old   February 27, 2008, 13:22
Default Hello everyone. As a newcom
nicasch
nicasch is on a distinguished road
Hello everyone.
As a newcomer I have two concrete questions concerning two div-schemes:
- Gauss limitedLinearV 1 and
- Gauss interfaceCompression.
I suppose that the interfaceCompression scheme does some blending between UD and CD, based on the blending factor (limiter) calculated according to either quartic or quadratic formula. Is this true? Or where is the limiter for this scheme used?
In limitedLinearV, I suppose that it is a kind of limited CD, but how is the scheme limited? Where is the limiter for this scheme used?
Is there any written text about these two schemes, or can anyone shortly explain me how they work?
Many thanks in advance, best regards.
nicasch is offline   Reply With Quote
Old   March 1, 2013, 07:55
Simon Tornros
tsimon is on a distinguished road
(sorry for bumping this old thread)
Why does the limiter in limitedLinear look like
max(min(twoByk_*r, 1), 0);
with twoByk_ = 2/k_ where 0 < k <1
when Sweby limiter is max(0,min(beta*r,1), min(r,beta)) with 1 < beta <2 ?
From what I can see this is not the same.
acgnipper likes this.
tsimon is offline   Reply With Quote
Old   March 12, 2013, 11:18
Robin Debroux
robdeb is on a distinguished road
I'm working with limitedLinear and I'm also trying to understand the limiter.
Have you found any informations about it?
Thank you.
robdeb is offline   Reply With Quote
Old   May 13, 2013, 11:18
giack is on a distinguished road
Hi to all,
I'm working with this limiter too and I would know if anybody found some information about it.
Thank to all
giack is offline   Reply With Quote
Old   May 21, 2014, 23:02
Eric Robertson
msuaeronautics is on a distinguished road
I think the twoByk_ term is just a calibrated term (i.e. a construct) that best suits what the limitedLinear scheme in OF is attempting to accomplish. I think it's to help place even more weight on higher-order differencing (in this case, central differencing vs upwind).
If you were to go through Jasak's thesis (pp. 98-99) and go back to theory, one could see that this method is actually pretty effective in enforcing either central differencing or upwinding based on the user-input (k).
One could actually show that, for a given ratio of successive gradients ("r"), inputting a low value of k (i.e. 0.1) would give more weight to central differencing, whereas a larger value (i.e. 0.8) places more emphasis on upwinding. I've also tried with beta values (1 < beta < 2) and the behavior is actually quite different. As such, I will have to conduct further studies.
Also, just hypothetically speaking, I don't think there would be any difference between:
and
max(0,min(twoByk_*r,1), min(r,twoByk_))
which would explain why (if my thought processes are anywhere near correct) the limiter is written the first way.
msuaeronautics is offline   Reply With Quote
Old   May 22, 2014, 01:46
T. Chourushi
Tushar@cfd is on a distinguished road
Are You Sure about this?
Tushar@cfd is offline   Reply With Quote
Old   May 22, 2014, 01:56
Eric Robertson
It is more of a thought experiment that warrants a better look.
Old   May 22, 2014, 05:23
T. Chourushi
Hello All,
I have some doubts with the representation of the following schemes in OpenFOAM. I asked this question here because it seems many of you are working on these.
(1)
default limitedLinear 1.0 phi;
What does "1.0 & phi" signifies? How it is related to the scheme?
(2)
default limitedVanLeer -2.0 3.0;
What is meant by "-2.0 & 3.0"? How come it is starting from "-2.0" and ending at "3.0"? How these numbers are determined? How it is related to the scheme?
Old   July 17, 2014, 05:52
Marvin
Marvin_Rauch is on a distinguished road
In the OpenFOAM Users Guide limitedLinear is said to be a TVD scheme. But by definition it is only TVD for k =1, otherwise it is not in the region of the psi -r diagram. Did I miss something or is the limiter not TVD?
Thanks for any help
Marvin_Rauch is offline   Reply With Quote
Old   July 23, 2014, 01:51
T. Chourushi
Thanks for any help
It is TVD for any of the value ranging from 0 to 1. But, the order of accuracy decrease as the k value decrease (i.e., less than 1). For k =1, it is most accurate.
I hope it cleared your doubt.
Best Luck!
Old   July 24, 2014, 06:20
Marvin
Tushar,
Looking at Versteeg p. 168:
Sweby (1984) has given necessary and sufficient conditions for a scheme to be TVD in terms of the r − ψ relationship:
• If 0<r<1 the upper limit is ψ(r)=2r, so for TVD schemes ψ®≤2r
• If r≥1 the upper limit is ψ(r)=2, so for TVD schemes ψ(r)≤2
but twor is greater 2 which wouldn't satisfy the first criteria. Can you give some reference for you're statement?
Thanks
Marvin
Best Luck!
Old   July 24, 2014, 09:26
T. Chourushi
Marvin,
Did you read it thoroughly before commenting? Anyways, If you re-read the same page no. 168-169 of the mentioned ebook it will clear your doubt.
I have attached a file of the same book with marked lines of page no. 168, which clears explains the TVD region.
Please find attached note with this comment.
Best Regards!
Old   September 8, 2014, 05:38
Marvin
Best Luck!
Some TVD/NVD schemes require a coefficient ψ,0 ≤ ψ ≤ 1 where ψ = 1 corresponds to TVD conformance, usually giving best convergence and ψ = 0 corresponds to best accuracy. Running with ψ = 1 is generally recommended.
(compare http://www.openfoam.org/docs/user/fvSchemes.php)
--> For k = 1 it is most stable. For k = 0 it is most accurate.
Sorry I didn't put that right earlier.
Further do I still not see why limitedLinear is TVD.
sourcecode: return max(min(twoByk_*r,1),0); (1)
If I draw that function (1) for k = 0.5 that is definitely not in the shaded region marked in verteeg for k <1. It demands that twoByk_ < 2.
Old   September 30, 2014, 21:23
Gecamp
desmoge is on a distinguished road
Hi Marvin,
I might be wrong here, but I think that the way the limiter has been implemented allows the scheme to behave as a TVD. In fact, with k=1, your limiter will be ψ(r) = 2*r. (as long as 2*r < 1). Conversely, with k = 0 (which means == SMALL), your ψ(r) becomes somethingBIG*r. This is most likely >> 1 and 'the switch' will choose ψ(r) = 1 as limiter. When such thing occurs, you are using pure CD to interpolate phi values on the internal faces.
Since I believe that the value r = (Phi_C - Phi_U)/(Phi_D - Phi_C) changes during the run, I expect the limiter ψ(r) to do the same. By choosing k = 1, one just increases the possibility to include in the interpolation process some UD diffusivity, I think.
desmoge is offline   Reply With Quote
Help!explicit multistage scheme with upwind scheme D .T. Main CFD Forum 1 June 4, 2003 04:42
References Lego Main CFD Forum 0 February 26, 2002 10:57
References on DNS/LES J. Xia Main CFD Forum 5 April 6, 2001 12:28
references sundar Main CFD Forum 1 June 21, 2000 13:47
References for MacCormack scheme L Srinivasa Mohan Main CFD Forum 1 March 10, 2000 14:45
