externalWallHeatFluxTemperature in internal void.
Like Tree1Likes
  • 1 Post By derekm
Old   April 21, 2014, 17:28
Default externalWallHeatFluxTemperature in internal void.
Derek Mitchell
derekm is on a distinguished road
Looking to have a heat source in my model but this is a little difficult in CHTmultiregionfoam. Some have modified the solver to add Joule heating. But there is now externalWallHeatFluxTemperature in openfoam 2.3.
My idea is to have a void in the the mesh(an unmeshed volume not a region) that is effectively "outside" in the terms of the model but is inside a solid.. This should alllow externalWallHeatFluxTemperature to be used and thus provide a heating source in terms of heat flux.
This is just an intermediate step in trying to learn how to fly this thing and study how the cavities and substances interact before developing "Honeybee" thermofluid general equations and of course a solver.
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   April 24, 2014, 07:03
Derek Mitchell
it didnt work ... now to try naming the void and then making the face have externalwallheatfluxtemperature
Old   April 25, 2014, 15:43
Derek Mitchell
Cracked it ... a solid region inside a solid region with both both boundaries using externalWallHeatFluxTemperature with the heatflux having opposite signs in each region. The inner region chills as the outer region heats. Thus a fixed heat flow without modifying the solver!!!
oumnion likes this.
Old   June 22, 2016, 10:22
Vishesh
visheshkapoor06 is on a distinguished road
Hello All,
I am trying to run a case of chtMultiRegionSimpleFoam based on the multiRegionHeaterRadiation example. My case has 8 solid blocks inside air. The air and blocks are inside a metal cabinet, and also touch the cabinet. The cabinet is in the atmosphere.
When i run the case, the temperature diverges and an error comes up. I am not able to diagnose the error. Please help!
Time = 1
Solving for fluid region domain0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0156926, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0130481, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0180424, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0671467, No Iterations 1
Min/max T:300 7709.26
GAMG: Solving for p_rgh, Initial residual = 0.88219, Final residual = 0.00738372, No Iterations 6
time step continuity errors : sum local = 21.78, global = -18.8129, cumulative = -18.8129
Min/max rho:0.2 1.15862
Solving for fluid region domain2
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0184007, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0246227, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0227786, No Iterations 1
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Attempt to cast type compressible::turbulentTemperatureCoupledBaffleMix ed to type compressible::turbulentTemperatureRadCoupledMixed[0]
[3]
[3] From function refCast<To>(From&)
[3] in file /home/kav9kor/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
[3]
visheshkapoor06 is offline   Reply With Quote
this->refValue()[faceI] = ?? peteryuan OpenFOAM Programming & Development 14 August 29, 2018 15:11
Boundary condition for 2d lid driven cavity using ghost cells quarkz Main CFD Forum 9 January 20, 2013 06:54
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 14:38
[OpenFOAM] Could you please help me liugx212 ParaView 4 December 22, 2005 17:55
