October 1, 2013, 04:49 |
Anton Kidess
Rep Power: 30 |
The first three solvers should always outperform smoothSolver. GAMG should outperform CG methods when not limited by communication (this is especially true for the pressure equation). If you're in doubt, just run a couple fixed timesteps with each of the solvers and you will very quickly find out where you can save time.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
October 1, 2013, 05:19 |
#3 | |
Andreas Groß
Rep Power: 13 |
As akidess already said, for p a good choice should be GAMG, for other fields I usually use PBiCG.
BICCG shouldn't be used any more: Quote:
October 7, 2013, 09:47 |
Mohsen KiaMansouri
Rep Power: 16 |
Dear Foamers
Have a look at the following references for more details: P. K. Khosla, and S. G. Rubin, “A diagonally dominant second-order accurate implicit scheme”, Computers and Fluids, 2:207-209, 1974. M. R. Hestens, and E. L. Steifel, “Method of conjugate gradients for solving linear systems”, Journal of Research, 29:409-436, 1952. D. A. H. Jacobs, “Preconditioned Conjugate Gradient methods for solving systems of algebraic equations”, Central Electricity Research Laboratories Report, RD/L/N193/80, 1980. H. A. Van Der Vorst, “Bi-CGSTAB: A fast and smoothly converging variant of Bi-CG for the solution of nonsymmetric linear systems”, SIAM J. Scientific Computing, 13(2):631-644, 1992.
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.” |
October 9, 2013, 00:52 |
Dr. B T KANNAN
Rep Power: 15 |
PBiCG is good.
-- KANNAN |
numeric schemes | Tobi | OpenFOAM Running, Solving & CFD | 0 | August 13, 2012 09:00 |
Better organization of Convective Term approximation schemes | Michail | CFD-Wiki | 0 | March 15, 2012 13:56 |
time stepping schemes for compressible DNS/LES | shyamdsundar | Main CFD Forum | 0 | January 15, 2010 00:15 |
ENERGY CONSERVATION SCHEMES! | Science Seeker | Main CFD Forum | 1 | May 24, 2001 13:13 |
Higher-order bounded convection schemes for pure advection with discontinuity | Anthony | Main CFD Forum | 3 | June 13, 1999 03:36 |
