Not continuous averaging when restarting a calculation
Like Tree3Likes
  • 1 Post By nik
  • 2 Post By h.ono
Old   June 19, 2013, 05:22
Default Not continuous averaging when restarting a calculation
nik
nicolas
nik is on a distinguished road
Hi to all,
I am using the fieldAverage function to calculate average quantities. I am using an updated version of OpenFOAM 2.2.x with the necessary fixes for the restarting to work, since there was a bug in the code (see http://www.openfoam.org/mantisbt/view.php?id=854). Restarting works just fine, my problem is that when I restart from a previous calculation, it seems that the averaging is not continuous as it should be. In order to look at the time evolution of a mean value I am using the probeFunction.
I can reproduce my problem using the cavity tutorial. I start averaging from the beginning up to 0.5 sec of simulation time. Then I restart the simulation for another 0.5 sec. Below are the functions objects used at the end of the controlDict:
functions
    fieldAverage1
        type            fieldAverage;
        functionObjectLibs ( "libfieldFunctionObjects.so" );
        enabled         true;
        outputControl   outputTime;
        resetOnOutput   false;
        resetOnRestart  false;
        fields
            p
                mean        on;
                prime2Mean  off;
                base        time;
    probesP
        type probes;
        functionObjectLibs ("libsampling.so");
        probeLocations
            (0.05 0.05 0.0)
        fields
            p pMean
I have also attached a figure showing the evolution of pMean with time, at a x=0.05, y=0.05 using the data from the probe function. This figure shows the discontinuous change in the evolution of the mean value, at t=0.5.
Am I doing something wrong with the flags that I am using, or is this a bug?
Thanks,
Nicolas
nik is offline   Reply With Quote
Old   June 19, 2013, 11:31
Bernhard
Bernhard is on a distinguished road
Did you cross-check with calculating the running mean of the sampled pressure itself?
Bernhard is offline   Reply With Quote
Old   June 20, 2013, 04:04
nik
nicolas
I have attached another figure showing the calculated running average of pressure, based on the values of pressure taken from the probe.
As you can see in the calculated running average there is no discontinuity. However, I can reproduce the discontinuity of pMean shown from the probes values, if I restart the averaging in my calculations, at t=0.5.
To me it is clear, that openFoam restarts the averaging of pMean that is written in the probes. My question is why, since I am telling it not to.
Nicolas
atulkjoy likes this.
Old   July 6, 2013, 22:59
Hiroki Ono
h.ono is on a distinguished road
I encountered the same problem. I noticed that issue by using Prime2Mean option. Prime2Mean value was always reseted to 0 when restarting.
I can reproduce my problem using the pisoFoam/pitzDaily tutorial like Nik done. I start averaging from the beginning up to 0.4 sec . Then I restart the simulation for another 0.4 sec.
When I use 2.2.0, this problem has not appeared. but in 2.2.x (latest), it comes.
I found that Foam::fieldAverage::initialize() function was not loaded in Foam::fieldAverage::read() in 2.2.x. and it will be loaded at 1st time call of Foam::fieldAverage::calcAverage().
https://github.com/OpenFOAM/OpenFOAM...fieldAverage.C
So, mean and P2Mean values will reset after calculation started.
I thought call of initialize() must be in Foam::fieldAverage::read().
I have tested to fix them with changing code as shown below.
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void Foam::fieldAverageFixed::read(const dictionary& dict)
    if (active_)
        initialised_ = false;
        dict.readIfPresent("resetOnRestart", resetOnRestart_);
        dict.readIfPresent("resetOnOutput", resetOnOutput_);
        dict.lookup("fields") >> faItems_;
        readAveragingProperties();
    if (!initialised_)
        initialize();
void Foam::fieldAverageFixed::execute()
    if (active_)
        calcAverages();
In my case, it seems to work fine. averaged values are same as using 2.2.0.
But I don't know whether it is truly correct or not.
Please check and post if something is wrong.
atulkjoy and JamesCC like this.
h.ono is offline   Reply With Quote
Old   July 23, 2013, 08:43
nik
nicolas
Dear Hiroki Ono,
thank you very much for the reply and suggested fix. Sorry for the late response but I had reported this bug to OpenFOAM and I was waiting for an official answer. I just got a reply that the issue has been fixed in the new version of 2.2.x. I guess based on your fix.
This thread is located at:
http://www.cfd-online.com/Forums/ope...-new-post.html
Regards,
Nicolas
Starting field averaging using libFunctionObject after certain time eelcovv OpenFOAM Programming & Development 25 December 7, 2015 23:28
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Nusselt averaging in Unsteady calculation elyyan FLUENT 0 August 7, 2006 14:48
unsteady calculation and Nusselt averaging elyyan FLUENT 0 August 4, 2006 15:32
Warning 097- AB Siemens 6 November 15, 2004 05:41
