best values for GAMG solver (nCellsInCoarsestLevel , nPreSweeps 0, nPostSweeps)
Like Tree12Likes
  • 2 Post By chegdan
  • 2 Post By KateEisenhower
  • 6 Post By Geon-Hong
  • 2 Post By makaveli_lcf
Old   May 5, 2013, 14:52
Default best values for GAMG solver (nCellsInCoarsestLevel , nPreSweeps 0, nPostSweeps)
mechy is on a distinguished road
what is the best values for GAMG parameters specially for
is there a formula to calculate those based on the number of cells ?
Regards
mechy is offline   Reply With Quote
Old   May 9, 2013, 12:17
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Try this
http://www.cfd-online.com/Forums/ope...on-meshes.html
There are several other threads, but the settings and concepts from this thread I use with my own simulations.
songwukong and rajibroy like this.
chegdan is offline   Reply With Quote
Old   May 10, 2013, 13:09
Dear Daniel
thanks so much for your answer.
in most of OF tutorials the value of nCellsInCoarsestLevel is set to 10 (or 20)
but in your link it is set to 500 (or sqrt(#cell))
do you know why OF used the 10 or 20 values ?
Regards
Old   May 10, 2013, 13:23
Daniel P. Combest
This is one of those situations where something has been tested and found to work for a particular situation. You can always try the sqrt(ncells), 10, 20, 50 or 100 and then see which one is the best for your case.
I have read that 10 or 20 for larger cases is too low and can be inefficient. Hence why I stay a bit higher with sqrt(nCells). However, its a case by case change.
Old   May 11, 2013, 13:24
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
I've seen similar changes in convergence speed by altering the nCellsInCoarsestLevel setting. In once case I had pressure converge twice as fast for a relatively large case @ 600k cells on about 50 processors. I don't have the solver settings on hand unfortunately.
It is definitely worth investigating before starting big parametric or large parallel cases.
kmooney is offline   Reply With Quote
Old   May 12, 2013, 02:09
Hi Daniel
by increasing the nCellsInCoarsestLevel value, the convergency increased but the high value of nCellsInCoarsestLevel may be increase the cpu time for solution
in other word by the high value of nCellsInCoarsestLevel solution converged, certainly
am I right ?
Regards
Old   February 9, 2017, 08:42
KateEisenhower is on a distinguished road
Does anyone know where this recommendation (nCellsInCoarsestLevel = sqrt(ncells) comes from?
Best regards,
Kate
Artur.Ant and kishore96 like this.
KateEisenhower is offline   Reply With Quote
Old   October 5, 2019, 10:46
Arthur
Artur.Ant is on a distinguished road
Remember that the OF tutorials are only demo tutorials. In openFoam there is no default options like in Fluent or any other commercial software; don't take the tutorial options as the one that work for sure!
Artur.Ant is offline   Reply With Quote
Old   October 7, 2019, 06:34
Trevor Kahan
trevorkahan is on a distinguished road
In most of OF tutorials the value of nCellsInCoarsestLevel is set to 10 (or 20).
basketball legends
trevorkahan is offline   Reply With Quote
Old   December 10, 2019, 20:26
Default Test on the nCellsInCoarsestLevel value
Geon-Hong Kim
Geon-Hong is on a distinguished road
I tested the parameter nCellsInCoarsestLevel and would like to share it here:
First of all, I tested using a ship simulation case with 5 Mil. Cells., which is a moderately large case. The GAMG solver was used to solve the pressure poisson equation. The test has been conducted three times for each case to measure the elapsed time for the first 100 iterations and then averaged. The domain was decomposed into 64, 128, and 256 subdomains. All the rest parameters, such as nPresweeps, nPostsweeps, etc., remained as the default values. Additionally, I also run the simulation by using a PCG solver with the DIC preconditioner to compare the results.
Elapsed Time(in seconds):
Solver      256      128        64
PCG        177.88    425.11    987.52
10         953.95   1102.91   1421.36
100       1426.52   1441.30   1592.25
200       1721.87   1657.35   1706.38
400       2043.28   1976.25   1901.76
800       2603.98   2530.56   2274.23
1600      3235.37   3445.93   2897.09
3200      4751.91   4750.79   3962.82
The numbers 10, 100, 200... in the first column are the nCellsInCoarsestLevel. As you can see, the computation took longer as the nCellsInCoarsestLevel increased.
Before I started this test, I expected that there should be an optimum point of the nCellsInCoarsestLevel parameter, but it wasn't. Rather the computational time gradually increased with the parameter. So I doubt if the sqrt(#Cells) is the optimum setup for the nCellsInCoarsestLevel (where does this recommendation come from?)
Even the GAMG solver showed worse performance relative to the DICPCG solver. (So I do not use the GAMG solver any longer)
Interestingly, the GAMG showed less degrade in speed performance than the DICPCG though the number of subdomains increased. Even lower subdomains showed faster performances in cases nCellsInCoarsestLevel>=200.
I hope to discuss this result with you and hear your opinion on it. If you have any suggestions or things to test, please let me know.
Regards,
Geon-Hong
Tobi, lourencosm, ztnuaa and 3 others like this.
Geon-Hong is offline   Reply With Quote
Old   February 5, 2021, 06:21
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Nice test Geon-Hong!
I have extended that for my self, and can report you that the optimum here will be which level of tolerance you get.
For my case (some MHD flow) the CG stopped converging and with 400 iterations remained at 1e-07.
Despite faster CG iterations, the GAMG allowed easily to get the convergence to 1e-14 in 15-20 iterations.
So, when comparing GAMG with CG solvers, you should check what you actually get for the solution of your problem.
Cheers,
Alexander
Solver      256      128        64
Regards,
Geon-Hong
Geon-Hong and Tobi like this.
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 13:39
Using a user-defined solver in OF ozzythewise OpenFOAM Running, Solving & CFD 3 February 8, 2011 16:28
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
Error during Solver cfd guy CFX 4 May 8, 2001 07:04
