cyclicAMI problem in MRF zone
Like Tree2Likes
  • 1 Post By linnemann
  • 1 Post By maHein
Old   April 4, 2012, 18:54
Default cyclicAMI problem in MRF zone
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Dear all
I'm trying to set a rotating blade case, using MRFsimpleFoam and periodic cyclicAMI faces in OF 2.1.x
Everything works, except a weird behaviour of cycliAMI faces inside MRFzone : they seem to be partially connected, and generate rotating strips, localized near the surface ! Please see the different images.
At the contrary the cyclicAMI faces located outside the MRF zone operate properly
I've been sticked with this problem for a few days, and I would be grateful to anybody who would help me
The complete case is downloadable here : http://www.jmichel.cmoi.cc/?q=node/79
Just run ./allRun
Thanks in advance
Jean-Michel
jmf is offline   Reply With Quote
Old   April 5, 2012, 14:39
Default cyclicAMI problem in MRFzone
jmf
Hi everybody
This is the direct shortcut to the case data :
http://www.jmichel.cmoi.cc/sites/jmi...BladeForum.zip
Best wishes
Jean-Michel
Old   April 6, 2012, 05:52
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi have you seen this?
http://www.openfoam.org/mantisbt/view.php?id=412
The reply from Andy about the nonRotating patches in the MRF dict.
Zbynek likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   April 6, 2012, 16:30
Default [Solved] cyclicAMI problem in MRF zone
jmf
Dear Linnemann
Many thanks for this answer, this line fixed the problem:
nonRotatingPatches (MRFcyclicTrail MRFcyclicLead);
You helped me a lot
Best wishes
Jean-Michel
Old   June 23, 2014, 13:46
Ash Sechler
windmachines is on a distinguished road
Adding the cyclicAMI patches to nonRotatingPatches() does not work for me. I am using OF2.2.2. My results are similar to the images posted here. After many different attempts i dont believe it is possible to use MRF in conjunction with cyclicAMI as periodic boundaries. I could be wrong, but i would say this is only possible with normal cyclic boundaries in 2.2.2
windmachines is offline   Reply With Quote
Old   June 23, 2014, 18:36
Ash Sechler
This also seems impossible in OF2.3.0. Can anyone support my claim or possibly suggest how it can be done? Thanks
Old   June 28, 2014, 15:56
jmf
Dear Ash
You might check that you have this in system/decomposeParDict :
preservePatches(yourMRFcyclic0 yourMRFcyclic1);
Hope that helps
Jean-Michel
Old   June 29, 2014, 09:26
maHein is on a distinguished road
Could you provide a example test case, where it is not working?
I'm using cyclicAMI as cyclic boundaries in conjunction with MRF and everything worked so far using OpenFOAM 2.2.x and 2.3.x.
Regards,
Martin
Vidal likes this.
maHein is offline   Reply With Quote
Old   August 14, 2014, 14:48
Ash Sechler
Martin and Jean-Michel,
thanks for you attention. I have started a another thread about this specific problem, with case and images attached:
http://www.cfd-online.com/Forums/ope...-mrf-zone.html
please let me know if you might have any insight.
thanks!
Ash
cyclic boundary, mrfsimplefoam
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
please help!!!fluid zone problem stk FLUENT 0 September 5, 2004 12:36
Problem in fluid zone!!! STK FLUENT 2 September 1, 2004 16:27
