buoyancy production term in turbulence model
Like Tree1Likes
  • 1 Post By ToulBraz
Old   April 24, 2011, 14:29
Default buoyancy production term in turbulence model
Fabian Braennstroem
braennstroem is on a distinguished road
I know, that for natural convection problems additional buoyancy production terms are used/needed in the turbulence equations
http://my.fit.edu/itresources/manual...ug/node482.htm
Related to this I have a few questions:
1) What is your experience with this additional production term?
2) How important is this for other turbulence models like the v2-f or k-omega-SST model?
3) Is there a difference for compressible/ideal gas and incompressible boussinesq solvers for using this additional production term (I expect not)?
4) What is your experience of using boussinesq approximation for higher temperature differences? For a difference of up to 100K I saw quite identical results evaluated by Darioush Gohari Barhaghi / Chalmers.
It would be nice, if you have some ideas and could recommend any papers related to these questions!
Best Regards!
Fabian
Btw. it seems, that the only available turbulence model for openfoam is the implementation of http://openfoamwiki.net/index.php/Co...EpsilonViollet
braennstroem is offline   Reply With Quote
Old   April 26, 2011, 07:27
Eugene de Villiers
eugene is on a distinguished road
Hi Fabian,
Here is a presentation from Launder et al that goes into some detail about the issues related to buoyancy and turbulence:
http://www.powershow.com/view/5c86-Z...t_presentation
By all accounts it is not just the turbulence model which needs modification, but also the wall functions if you are running a high Re mesh. I suggest you read the related papers as well.
Certainly, our experience with the Fluent source term approach has not shown any noticeable benefits for natural convection dominated problems typical of HVAC applications. I imagine the influence will be more pronounced at larger dT though.
It is quite difficult to give a clear-cut range of applicability for the Boussinesq approximation as its behaviour is entirely case dependent. If you look at the derivation of the Boussinesq approximation, it is not necessarily the gravity term that causes the largest deviations due to the assumption of constant pressure. The secondary effects of non-constant density can be quite pronounced, especially in its effect on the heat capacity via Cp. In general, the smaller the pressure range is, the larger the accurate temperature range will be. Larger amounts of forced convection will also reduce the relative impact of the Boussinesq approximation.
eugene is offline   Reply With Quote
Old   April 26, 2011, 07:29
Eugene de Villiers
I forgot to add this: a great article detailing the derivation of the Boussinesq approximation with some discussion of its range of applicability:
http://articles.adsabs.harvard.edu/c...IF&classic=YES
Old   April 27, 2011, 14:39
Fabian Braennstroem
Hello Eugene,
thanks for your reply and for the interesting links! Yes, you are correct with the wall treatment for higher yplus values. Related to the production term, I remember, that there were some study of Kriegel with Fluent for displacement ventilation playing around with the productions term for the dissipition equ. using a k-epsilon variant... unfortunately I do not know, if it changed a lot.
Thanks again!
Fabian
Old   May 25, 2011, 11:22
Aram Amouzandeh
mabinty is on a distinguished road
a while ago I implemented a buoyancy augmentation for the standard k-eps model in OF based on the Generalized Gradient Diffusion Hypothesis. Comparison with experimental results of a vertical round turbulent plume showed improved results, similar to the study of Maele and Merci: Application of two buoyancy-modified k-eps turbulence models to different types of buoyant plumes, Fire Safety Journal, 2006, 41, 122-138.
Aram
mabinty is offline   Reply With Quote
Old   January 13, 2012, 05:43
Post
ToulBraz is on a distinguished road
I've downloaded Viollet's k-e model from :
I made some mods in order to make it useable with OpenFOAM 2.0. I think I succeeded as it seems to work (but I'm quite new to OF so,....).
However, I lately understood that the implementation is only for incompressible flows, so I can't use it with buoyantSimpleFoam (only with boussinesqBuoyantSimpleFoam).
Does anyone have some hints on how I should proceed to make it work for compressible flows ?
Thanks in advance
hswzzz likes this.
ToulBraz is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
"Full" buoyancy model in CFX Jade M Main CFD Forum 2 March 18, 2010 12:08
Fan heater model: what turbulence source to use? andy20 Main CFD Forum 0 March 2, 2008 12:46
non-physical production of k, k-w turbulence model David Garrido Main CFD Forum 9 September 17, 1999 15:47
Turbulence in Turbomachinery Erich F. Main CFD Forum 15 June 22, 1999 23:37
