How to deal with new added cells
Like Tree2Likes
  • 2 Post By hjasak
Old   October 5, 2005, 22:54
Default If a new cell is added in the
chen_jun
If a new cell is added in the fvMesh, what should I do to set the cell value (such as pressure and velocity) for transient calculation?
Here is the error I have got:
--> FOAM FATAL ERROR : internal field size 2504 does not match
the number of points 5474
the number of internal faces 4864
or the number of cells 2502
From function fvPatchField<type>::checkInternalField() const
in file /home/chenjun/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/fvPatchField.C at line 67.
FOAM aborting
Old   October 6, 2005, 16:18
Default This is from using mapFields?
Mattijs Janssens
mattijs is on a distinguished road
This is from using mapFields? Check how you invoke mapFields. There is a tutorial which uses it.
mattijs is offline   Reply With Quote
Old   October 6, 2005, 23:33
Default This is from icoFoam, which I
chen_jun
This is from icoFoam, which I have modified to change mesh in runtime.
I also want to know how volFields know their old value if the cell have been changed. Using mapField?
Old   October 7, 2005, 05:24
Default If you wish to add a new cell
Hrvoje Jasak
If you wish to add a new cell into the mesh during the simulation, you are really executing a topological change: as a consequence, the mesh numbering will probably change as well.
When the data is copied from one mesh to another using topo change support in OpenFOAM, simple data mapping will not do: we work out the detailed mapping between the old and new mesh and enforce consistency and conservation. In short, the data mapping process creates on object of type mapPolyMesh which contains the mapping info. Then, each discretisation executes the appropriate mapping based on this info, e.g. in fvMesh:
// Map all the volFields in the objectRegistry
MapGeometricFields<scalar,>(mapper);
MapGeometricFields<vector,>(mapper);
MapGeometricFields<tensor,>(mapper);
// Map all the surfaceFields in the objectRegistry
// Map all the clouds in the objectRegistry
mapClouds(*this, meshMap);
which moves the stuff from the old mesh to the new one.
Enjoy,
Hrv
mm.abdollahzadeh and hua1015 like this.
Hrvoje Jasak
How can Temperature be added into interFoam ttdtud OpenFOAM Running, Solving & CFD 14 September 7, 2013 08:32
help:uds source added to boundary cells FredPacheo FLUENT 5 September 5, 2008 06:45
added mass Kuba Broniszewski FLUENT 2 February 23, 2007 10:39
How to deal with "dummy" cells by FVM Smith Gearheart Main CFD Forum 7 November 15, 2002 01:35
Effect of added CPU ? steve podleski Main CFD Forum 8 August 10, 1999 21:26
