CavitatingFoam Equations
Like Tree3Likes
  • 2 Post By schmidt_d
  • 1 Post By FlyFox
Old   July 7, 2007, 07:54
Default Hi I am studing about the new
morteza
morteza is on a distinguished road
Hi
I am studing about the new cavitatingFoam implemented in openfoam-1.4.
Can someone tell me about the governing equations are used in this solver(or reference to equations).
Thanks
morteza
morteza is offline   Reply With Quote
Old   July 7, 2007, 12:36
Default Morteza, cavitatingFoam has a
David P. Schmidt
schmidt_d is on a distinguished road
Morteza,
cavitatingFoam has a few different models for the physics. I can tell you about the "Wallis" model. Wallis derived the equation for the speed of sound through a bubbly mixture in thermal equilibrium. I used this speed of sound relationship as the basis of a cavitation model in the mid 1990's. My other contribution was to find a closed-form integral to produce a barotropic equation of state.
cavitatingFoam shares the same physical basis, when used with the Wallis model. However, the numerics and behavior are quite different. My code used the explicit expression for pressure which produces a low-cost per time step, but can only be used efficiently for something like diesel fuel injection, where the velocity is the same order of magnitude as the speed of sound. The cavitatingFoam code can operate efficiently at lower velocities.
For more info, I have posted my dissertation at:
http://www.ecs.umass.edu/~schmidt/Sc...ssertation.pdf
schmidt_d is offline   Reply With Quote
Old   July 7, 2007, 15:45
Default David, Thanks for your quick
morteza
David,
Thanks for your quick reply.
Morteza
Old   July 8, 2007, 10:28
Default Is it possible to deal with lo
Connie Scofield
zjucfd is on a distinguished road
Is it possible to deal with low mach problems?
hi, Dr. Schmidt,
You said "The cavitatingFoam code can operate efficiently at lower velocities". But how could it be done? I attempted to simulate a cavitating flow around a hydrofoil at low mach number using cavitatingFoam, but can not get a physically reasonable results.
zjucfd is offline   Reply With Quote
Old   July 9, 2007, 12:11
Default Connie, I am mostly an expe
David P. Schmidt
Connie,
I am mostly an expert at my own code, which I wrote using very simple, but pretty stable numerics. The cavitatingFoam code comes from Henry Weller. Fabian Peng Karholm (spelling?) uses it a lot.
From what I see, the cavitatingFoam code tries to couple the pressure solution pretty tightly with the eqn. of state and continuity, so that you are treating accoustic waves implicitly. You are trying to avoid having to respect a Courant number that contains the speed of sound in the velocity, because then the stable time step size would have to be tiny. With cavitatingFoam you can take time steps where this accoustic CFL number is much greater than 1.0. I am not sure how high you can go, but the tutoral case operates at an accoustic CFL number of 50, if memory serves.
I've had some stability problems with cavitatingFoam too. I haven't invested enough time to know whether the problem is with my inputs or not. I can say this: pressure with a barotropic model should always be positive. But because of the discretization of the pressure equation, cavitatingFoam can predict negative pressures.
If you are going to do a hydrofoil, I am not sure how much sense it makes to use a barotropic model anyway. In my thesis, I justify using a barotropic model based on typical fuel injection conditions. As length scales get large, the physics might well change. And if you do something where you have to keep the accoustic courant number < 1 for a big old hydrofoil, you will have to wait a long, long time for the code to run.
DPS
sharonyue and peyman.havaej like this.
Old   May 11, 2010, 12:43
Marta's Avatar
Marta Lazzarin
Marta is on a distinguished road
Dear Foamers, i am experiencing a negative pressure too with cavitatingFoam...i read in this post that this can be due to the pressure equation discretization, but what does this exactly mean? is there a way to avoid this that you can advice?
Thank you very much!
Marta
Marta is offline   Reply With Quote
Old   October 14, 2010, 06:16
Default compressibility models
jml
Jml
jml is on a distinguished road
I have read your post about compressibility models and I have some questions. I have used cavitatingFoam with diesel injectors with a linear model of compressibiliy, and it works quite well.
Now, I want to improve the realism of the simulations using a "Wallis" or a "Chung" model. However when I used these models the simulation has a lot of problems of convergence, giving unreasonable values of density, pressure.. The only difference between the linear and the other models in the configuration of the case is the rhomin parameter (0.1).
Anyone know what are the reason of these problems?
Thanks
jml is offline   Reply With Quote
Old   May 18, 2014, 00:00
yehanyu
yhy20081016 is on a distinguished road
Originally Posted by morteza View Post
Hi
Thanks
morteza
You can go through the codes in the "barotropicCompressibilityModel" folder. There is a scalar field called "psi_". This variable is the product of density and the isentropic compressibility:
psi_=rho*alpha
where rho is density, and alpha is isentropic compressibility. The definition of "isentropic compressibility" can be found in many engineering thermodynamics text books, such as
Moran M. J. et al. Fundamentals of Engineering Thermodynamics, 7th ed. John Wiley & Sons, 2011
yhy20081016 is offline   Reply With Quote
Old   May 13, 2015, 15:04
alvaro
alvariten is on a distinguished road
Thanks
Hi jml,
I'm using cavitatingFoam (OF v.2.3.x) with diesel injectors and convergences issues similar to yours are appearing. I am using the default configuration of tutorial case. Did you get solve the problems finally? In this case, What did you do?
Thanks in advance.
alvariten is offline   Reply With Quote
Old   March 29, 2016, 10:33
Sandy Lee
sandy is on a distinguished road
Hi Schmidt,
I attempt to fo
follow your cavitatingFoam to implement the barotropic relations proposed by Delannoy & Kueny in 1998, however, I don't know how to write the pEqn.C . Could you help me?
Sandy
sandy is offline   Reply With Quote
Old   April 10, 2018, 10:17
Jose Rothkegel
FlyFox is on a distinguished road
Does anyone know if there is a document made by the author of the solver, whether internal or external, describing the implementation of cavitatingFoam? I'm trying to get a reference.
Regards
FlyFox is offline   Reply With Quote
Old   October 5, 2020, 13:05
Didu is on a distinguished road
Dear Foamers,
I need to develop a setup in OpenFoam for water hammer, and I came across cavitatingFoam and during the theoretical analysis it looked perfect.
During some tests, with several meshes, cavitatingFoam is not able to describe the simple flow in a pipe, not the velocity profile, or even the head loss.
Does anyone have the same problem?
DiDu
Didu is offline   Reply With Quote
Old   October 5, 2020, 13:07
Jose Rothkegel
Originally Posted by Didu View Post
Dear Foamers,
DiDu
You will need to provide more info. What geometry and what general setup are you using?
Didu likes this.
Old   October 5, 2020, 13:15
Geometry=pipe with Radius=0.01m, with 1.5 m long,
Setup=constant pressure in the inlet and a velocity in the outlet
Many thanks for your time!!
https://drive.google.com/file/d/1XNq...ew?usp=sharing
CavitatingFoam psil psiv kyubi OpenFOAM Running, Solving & CFD 8 February 17, 2020 17:23
CavitatingFoam for Diesel injector nozzles javier_salvador OpenFOAM Running, Solving & CFD 0 July 16, 2008 10:37
CavitatingFoam with a moving mesh mass conservation error idosil OpenFOAM Running, Solving & CFD 3 November 27, 2007 18:27
Problem with cavitatingFoam clo OpenFOAM Running, Solving & CFD 1 June 7, 2007 12:53
LES equations Daniel Main CFD Forum 14 March 26, 2005 08:30
