TimeVaryingUniformFixedValue
Like Tree1Likes
  • 1 Post By heavy_user
Old   February 7, 2008, 11:07
Default Dear Foamers, I tried to im
Holger Marschall
holger_marschall is on a distinguished road
Send a message via Skype™ to holger_marschall
Dear Foamers,
I tried to implement a TimeVaryingUniformFixedValue b.c. for a velocity inlet:
inlet.dat:
N
t0 (v1 v2 v3)
t1 (v1 v2 v3)
t2 (v1 v2 v3)
tN (v1 v2 v3)
in 0/U:
INLET
type timeVaryingUniformFixedValue;
timeDataFileName "inlet.dat";
But the error message I got when I started the simulation run:
--> FOAM FATAL IO ERROR : wrong token type - expected Scalar found on line 3 the punctuation token '('
file: inlet.dat at line 3.
From function operator>>(Istream&, Scalar&)
in file lnInclude/Scalar.C at line 85.
FOAM exiting
Can anybody tell me what I did wrong? Did I use the right syntax in inlet.dat?
Holger
Holger Marschall
web: http://www.holger-marschall.info
mail: holgermarschall@yahoo.de
holger_marschall is offline   Reply With Quote
Old   February 7, 2008, 13:54
Default Hello Holger, Good Evening!
Philippose Rajan
philippose will become famous soon enough
Hello Holger,
Good Evening!
The TimeVaryingUniformFixedValue boundary condition does not accept vectors in the data file... it can only handle scalars.
However, to use this boundary condition in the case of a vector (as in your case, velocity), all you need to do, is to specify the magnitude of the vector.
The boundary condition automatically calculates the surface normal of each face on the patch(es) you have specified, and applies the magnitude you have given in the data file along the direction of the surface normal.
The sign convention is such that, if you give a positive number for the magnitude in the time data file, the velocity will be pointed into your domain (and as mentioned, in a direction normal to each face on each specified patch).
Enjoy and have a nice day!
Philippose
philippose is offline   Reply With Quote
Old   February 7, 2008, 14:12
Default Hello, thanks a lot! It wor
Holger Marschall
thanks a lot! It works now
P.S.: I searched even on google for that information. Don't know if somebody has access to http://www.durun.cn/?p=320 and could change the wrong thread there.
best regards,
Holger
Holger Marschall
Old   December 17, 2009, 13:25
heavy_user is on a distinguished road
Hi There,
I am trying to have a time dependent inlet-condition.
(I want the velocity to raise, since pressure corretion messes up when i start up with the high velocity).
But I get a message with which i cant deal.
Create mesh for time = 0
Reading g
Reading thermophysical properties
Reading field T
Reading field p
Reading field U
Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 27 the doubleScalar 100000
file: /home/OpenFOAM/OpenFOAM-1.6/OWN/jetflame/V4/0/U::value at line 27.
From function Istream::readBegin(const char*)
in file db/IOstreams/IOstreams/Istream.C at line 87.
FOAM exiting
the .dat file:
( 0.00005 ( 0 0 0.1000 ) )
( 0.00010 ( 0 0 0.2058 ) )
( 0.00015 ( 0 0 0.3116 ) )
( 0.00020 ( 0 0 0.4174 ) )
( 0.00025 ( 0 0 0.5232 ) )
( 0.00030 ( 0 0 0.6290 ) )
( 0.00035 ( 0 0 0.7348 ) )
( 0.00040 ( 0 0 0.8406 ) )
( 0.00045 ( 0 0 0.9464 ) )
( 0.00050 ( 0 0 1.0522 ) )
( 0.00055 ( 0 0 1.1580 ) )
( 0.00060 ( 0 0 1.2638 ) )
( 0.00065 ( 0 0 1.3696 ) )
( 0.00070 ( 0 0 1.4754 ) )
( 0.00075 ( 0 0 1.5812 ) )
( 0.00080 ( 0 0 1.6870 ) )
( 0.00085 ( 0 0 1.7928 ) )
( 0.00090 ( 0 0 1.8986 ) )
( 0.00095 ( 0 0 2.0044 ) )
( 0.00100 ( 0 0 2.1102 ) )
( 0.00105 ( 0 0 2.2160 ) )
( 0.00110 ( 0 0 2.3218 ) )
( 0.00115 ( 0 0 2.4276 ) )
( 0.00120 ( 0 0 2.5334 ) )
( 0.00125 ( 0 0 2.6392 ) )
( 0.00130 ( 0 0 2.7450 ) )
( 0.00135 ( 0 0 2.8508 ) ) // line 27 (stating from line 0)
( 0.00140 ( 0 0 2.9566 ) )
( 0.00145 ( 0 0 3.0624 ) )
( 0.00150 ( 0 0 3.1682 ) )
( 0.00155 ( 0 0 3.2740 ) )
( 0.00160 ( 0 0 3.3798 ) )
( 0.00165 ( 0 0 3.4856 ) )
( 0.00170 ( 0 0 3.5914 ) )
( 0.00175 ( 0 0 3.6972 ) )
( 0.00180 ( 0 0 3.8030 ) )
( 0.00185 ( 0 0 3.9088 ) )
( 0.00190 ( 0 0 4.0146 ) )
( 0.00195 ( 0 0 4.1204 ) )
I cant find a missing "(" and there is no value "100000" ->
Any Ideas????
regards
Flukato likes this.
heavy_user is offline   Reply With Quote
Old   August 10, 2013, 15:47
Islam Elqatary
Islam ElQatary is on a distinguished road
Originally Posted by philippose View Post
Hello Holger,
Good Evening!
Philippose
Hello
Does anyone know how to change the inlet speed direction with time?
like if I want to change the angle of attack on the airfoil with time
thanks
Islam ElQatary is offline   Reply With Quote
TimeVaryingUniformFixedValue BC in foam 15 nzy102 OpenFOAM Running, Solving & CFD 5 August 19, 2008 09:08
TimeVaryingUniformFixedValue with sonicLiquidFoam Bugs amp Fixes chnrdu OpenFOAM Bugs 1 May 21, 2008 10:52
TimeVaryingUniformFixedValue does not work as a pressureInlet with sonicLiquidFoam nishant_hull OpenFOAM Running, Solving & CFD 5 May 21, 2008 09:54
TimeVaryingUniformFixedValue boundary condition liu OpenFOAM Running, Solving & CFD 1 October 12, 2007 14:19
