August 6, 2008, 11:35 |
Hi!
I'm working with OpenFOAM
Claudio Feliciani
Hi!
I'm working with OpenFOAM for a simulation of the liquid steel behaviour for a Twin Roll Casting maschine. I succesfully created a mesh and added the necessary boundary conditions. When I start the computation with interFoam after the second time-iteration a get an error message: "Floating point exception". I searched with google the meaning of this error but there's not lot of documentation. Could you please tell me which could be one of the possible reason that yield such an error message? Thank you, Claudio Feliciani |
August 6, 2008, 12:36 |
Your solver blew up because of
Hrvoje Jasak
Rep Power: 33 |
Your solver blew up because of an illegal mathematical operation, like division by zero. I would think this is to do with either your initial/boundary conditions or material properties. For example, having zero density would do something like this.
Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
August 7, 2008, 09:20 |
I've solved the problem by set
Claudio Feliciani
I've solved the problem by setting:
unset FOAM_SIGFPE Now the simulation is running and the results seem to be good. Actually I know what the command unset FOAM_SIGFPE (it tell OpenFOAM to not send the term signal to the CPU in case of an illegal operation, if I've not understand wrong), but what could be the risks by using that method to remove the "Floating point exception" problem? The same topic were discussed in http://www.cfd-online.com/OpenFOAM_D...tml?1201770596 but no answer were finally given. Thanks, Claudio |
December 21, 2010, 15:04 |
N. A.
Rep Power: 16 |
Hi Claudio,
where do you "unste FOAM_SIGFPE". in etc/bashrc or some where else Thanks, Nir |
December 22, 2010, 09:42 |
David Boger
Rep Power: 17 |
Assuming you are using a bash shell, I would put it in your .bashrc
David A. Boger |
February 8, 2012, 02:02 |
Floating error
Rep Power: 14 |
Hello
i am having floating error :invalid number problem. I am working train in tunnel. Can any body help me. My email is sheikhnasir39@gmail.com |
April 17, 2013, 05:43 |
starter
Rep Power: 16 |
Claudio
I am doing LES of my geometry. In which dictionary do you put unset FOAM_SIGFPE. My dictionaries are what can be found in pitzDaily tutorial in pisoFOam. I shall be very grateful for your response. Regards |
November 19, 2023, 05:48 |
Rohan
Rep Power: 3 |
Where do i put the unset foam_sig, im stuck with the floating point exception would really appreciate ur reply
November 27, 2023, 05:22 |
#9 |
S.M. Nafiz Ahmed
November 27, 2023, 05:29 |
#10 |
Rohan
Rep Power: 3 |
Thank you very much
November 29, 2023, 13:44 |
#11 |
Anurag
Rep Power: 3 |
If i use a job script to submit a openfoam job on hpc shall I put unset command in my jobscript before putting the interFoam command??
many thanks. |
error:floating point exception | santosh | FLUENT | 2 | February 8, 2012 03:06 |
Error : floating point exception; overflow. | maryam | CFX | 3 | May 18, 2010 08:44 |
CFX error, Floating point exception | Riyaz | CFX | 4 | May 18, 2010 02:13 |
CFX error, Floating point exception | Riyaz | Main CFD Forum | 0 | November 14, 2008 07:30 |
Error: floating point exception | Joern | FLUENT | 0 | January 23, 2004 05:27 |
