Problems with adjustable timestep control and maxCo Number
Like Tree1Likes
  • 1 Post By wolle1982
Old   November 18, 2008, 06:46
Default Hi all, I'm using OF 1.5 an
Wolfgang Heydlauff
wolle1982 will become famous soon enough
Hi all,
I'm using OF 1.5 an try to make a turbFoam simulation run with adjustable Timestep control.
But it doesn't work. the solver always keeps the preset deltaT. NO adjustment is done at all!!
As I read in this forum ( http://www.cfd-online.com/cgi-bin/Op...cus/discus.cgi ) to make it work I have to change my turboFoam.C.
But by recompiling it there appears an error:
.../setInitialDeltaT.H: In function 'int main(int, char**)':
.../setInitialDeltaT.H36: error 'CoNum was not declared in this scope
turbFoam wurde nicht aktualisiert
How can I correct the missing declaration?
Or should this work in OF1.5 already rigth? If so, what do I have to change or adjust and in what file?
Thanks a lot.
wolle1982 is offline   Reply With Quote
Old   November 18, 2008, 07:21
Default in turbFoam.C After: # inc
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
in turbFoam.C
After:
# include "initContinuityErrs.H"
add this:
# include "readTimeControls.H"
and after:
# include "CourantNo.H"
add this:
# include "setDeltaT.H"
and run wmake.
in system/controlDict add these lines.
adjustTimeStep on;
maxCo 0.3;
niklas is offline   Reply With Quote
Old   November 18, 2008, 08:55
Default Thank you. This solved it fina
Wolfgang Heydlauff
Thank you. This solved it finally!!
As a conclution for all others: My turbFoam.C now looks like this:
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
# include "setInitialDeltaT.H"
Info<< "\nStarting time loop\n" << endl;
for (runTime++; !runTime.end(); runTime++)
Info<< "Time = " << runTime.timeName() << nl << endl;
# include "readPISOControls.H"
// Pressure-velocity PISO corrector
My controlDict has the following lines attached
adjustTimeStep yes;
maxCo 5;
maxDeltaT 0.01;
after that I did "wclean" and "wmake" inside the ../incompressible/turbFoam/ directory.
Finally it works.
mn14cat likes this.
Old   June 18, 2009, 14:00
Default courant number bigger in icoFoam
xianghong wu
wendywu is on a distinguished road
Originally Posted by niklas View Post
in turbFoam.C
After:
add this:
and after:
add this:
and run wmake.
adjustTimeStep on;
maxCo 0.3;
I also met this problem, when I run icoFoam on a case with complex 3D shape. courant number becomes bigger and bigger. it seems non reasonable.
Do I need to correct it like what you said here?
Thank you.
Wendy.
wendywu is offline   Reply With Quote
Old   July 27, 2011, 06:40
Tibo
megacrout is on a distinguished road
Hi Niklas,
Thanks a lot, that was exactly what I needed.
I actually did it with pisoFoam, it works great.
Tibo
megacrout is offline   Reply With Quote
Old   September 24, 2015, 11:07
Default DelT, adjustableTIme,courantNumber
Isaac Mark Joseph Manasseh
mar001 is on a distinguished road
I have set my transient turbulent flow simulation to adjustable time steps. And also set the max. COurant number to 1. I am simulating flow over a smooth cylinder. While using my FFT MATLAB script to plot the dominant frequency as the Strouhal's frequency i realized I got two spikes. One at 2.575 and another peak at 2.795. Reynolds number of : 5.5*10^5. Is this is a physical phenomenon or that my time step delT has been so small to capture the dominant frequency twice. If yes what is the correction that I can do?
mar001 is offline   Reply With Quote
MaxCo with interFoam sega OpenFOAM Running, Solving & CFD 2 January 6, 2009 05:05
Timestep control via CEL? Claudia CFX 7 September 14, 2007 06:00
change timestep after a certain iteration number Sans CFX 5 June 3, 2007 06:17
Timestep-Control (Subroutine) Gabor CFX 1 November 14, 2005 02:22
