an odd Fatal Error:ExpressionResult::calcIsSingleValueInternal< bool>() |
August 10, 2015, 20:12 |
Ehsan
Rep Power: 27 |
its the output of my case run. its so weird and unclear about the source of the error:
Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport sutherland; thermo janaf; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; c1 10; Cmu 0.09; Prt 1; b1 1; F3 false; } fluxScheme: Kurganov Starting time loop Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport sutherland; thermo janaf; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Creating expression field CRRv ...swak4Foam: Allocating new repository for sampledMeshes swak4Foam: Allocating new repository for sampledGlobalVariables "Loaded plugin functions for 'FieldValueExpressionDriver':" rhoTurb_R: "volSymmTensorField rhoTurb_R()" rhoTurb_alphaEff: "volScalarField rhoTurb_alphaEff()" rhoTurb_devRhoReff: "volSymmTensorField rhoTurb_devRhoReff()" rhoTurb_epsilon: "volScalarField rhoTurb_epsilon()" rhoTurb_k: "volScalarField rhoTurb_k()" rhoTurb_muEff: "volScalarField rhoTurb_muEff()" rhoTurb_mut: "volScalarField rhoTurb_mut()" thermo_Cp: "volScalarField thermo_Cp()" thermo_Cv: "volScalarField thermo_Cv()" thermo_T: "volScalarField thermo_T()" thermo_alpha: "volScalarField thermo_alpha()" thermo_hc: "volScalarField thermo_hc()" thermo_he: "volScalarField thermo_he()" thermo_mu: "volScalarField thermo_mu()" thermo_p: "volScalarField thermo_p()" thermo_psi: "volScalarField thermo_psi()" thermo_rho: "volScalarField thermo_rho()" swak4Foam: Setting default mesh type:volScalarField Creating expression field CRRp ... type:volScalarField faceSource massflow_left: total faces = 54 total area = 1.2e-05 faceSource Average_left: total faces = 54 total area = 1.2e-05 faceSource massflow_right: total faces = 54 total area = 1.2e-05 faceSource Average_right: total faces = 54 total area = 1.2e-05 faceSource n1_Average: total faces = 868 total area = 1.2e-05 faceSource n2_Average: total faces = 216 total area = 1.2e-05 swak4Foam: Allocating new repository for sampledSurfaces faceSource n3_Average: total faces = 868 total area = 1.2e-05 faceSource h1_Average: total faces = 11204 total area = 0.000207 faceSource h2_Average: total faces = 2800 total area = 0.000207 faceSource h3_Average: total faces = 11204 total area = 0.000207 Mean and max Courant Numbers = 0.0284841995776 0.0869432167197 deltaT = 1.19047619048e-08 Time = 1.1904762e-08 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 --> FOAM FATAL ERROR: This specialisation is not implemented From function ExpressionResult::calcIsSingleValueInternal<bool>() in file ExpressionResult/ExpressionResult.C at line 373. FOAM exiting the case was executing well before the previous installation of OF been cleared by accident. I just install everything again.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
August 11, 2015, 06:02 |
Joachim Herb
Rep Power: 22 |
I guess more information is necessary to help you: Which version of OpenFOAM, which solver.
Googling the error message results in this hit: http://sourceforge.net/p/openfoam-ex...27a1d73c5e73f/ Do you use swak4foam? |
August 11, 2015, 06:28 |
Ehsan
Rep Power: 27 |
Hi dear Joachim,
I use OF 2.4.0, and the solver is rhoCentralFoam and yes I use groovyBC from swak4Foam code package. is more thing need to be said?
August 12, 2015, 17:21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
This is one of those situations where I tend to sigh... almost in desperation . I won't even bother to rant about this... I say this because, although this question might be useful for many people in the future, the question did not follow the proposed guidelines: http://www.cfd-online.com/Forums/ope...-get-help.html @Ehsan:
Best regards, Bruno
Last edited by wyldckat; August 12, 2015 at 17:25. Reason: fixed typo and added #5 |
August 13, 2015, 05:32 |
Ehsan
Rep Power: 27 |
Hello dear Bruno,
sorry if low information bothered you, because it was running well before and as you helped a lot,all aspects of the problem was investigated and issues had been solved and I wonder why this error is shown after all those things anyway, I tried to run the case without my edited solver and without parallel run, in the simplest form I used the original solver of OF: rhoCentralFoam and an error on Cp and Cv fields I received in return of the Fatal Error mentioned here. its in http://www.cfd-online.com/Forums/ope...tml#post559385 first of all we may better see what's happening about the specified fields, then if the current error was persisted go for more details and I will submit BCs and other important parts of the case. thanks a lot.
August 14, 2015, 16:29 |
#6 | |
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
Simultaneously, since you sent me the case, I could properly diagnose this problem as well. Remember where I wrote in the previous post: Code:
a = 1 == 2; Code:
"port2=(t1+c1r<t_mappedr && t_mappedr<t1+c2r);" The solution was to change this to: Code:
"port2=(t1+c1r<t_mappedr && t_mappedr<t1+c2r) ? 1 : 0;" Now that I think about it, I forgot to point out on the other post that this was the workaround... but since you didn't specifically ask how to fix the problem... Several lines had to be fixed in the case you sent me, because a lot of them were using that "bool" type of expression. The strange thing that I found is that you already had this kind of conversion of boolean to number done in a few places, for example: Code:
fractionExpression "(wall_left) || (port3 && M3>=1) || (port1 && M1>=1)? 1 : 0"; This makes me vaguely remember that we already had seen this problem a few years ago... but I can't remember exactly what happened. Perhaps I provided you a modified swak4Foam that could handle this type of data?... I can't remember... I went Googling a bit and found this post of yours: http://www.cfd-online.com/Forums/ope...tml#post430096 - post #6, but in post #2 on that same thread I indicated an implementation you had a day before #6. The one on post #2 had this same kind of buggy expression: Code:
fractionExpression "port3 || port1 && phi<=0 ? 1 : 0"; Code:
fractionExpression "(port3==1) || (port1==1) && phi<=0 ? 1 : 0"; Anyway, the problem for this current thread seems to be solved. Best regards, Bruno
August 14, 2015, 19:37 |
Ehsan
Rep Power: 27 |
dear Bruno, I am very so thankful of you, I don't know how to thank you. you are a real angel ;-)
and yes I think you or Bernhard gave me a modified version of swak4Foam that boolean calculation was included and Bernhard wanted me to leave a comment about the bug in the related page of bugs so that he remember to include it for next versions. haven't you had that version now to give me please? in this thread it seems Boolean issue must have been solved! http://www.cfd-online.com/Forums/ope...tml#post440973 thanks a lot again.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. Last edited by immortality; August 16, 2015 at 01:55. |
August 16, 2015, 07:44 |
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
I've re-sent you via email the version that Bernhard had done back then. The associated bug report was this one: http://sourceforge.net/p/openfoam-ex...swak4foam/172/ This feature got lost in the commit that jherb pointed out. I guess you'll had to report this bug again, if you want it fixed again. edit: Now that I think about it... the version back then was swak4Foam 0.2.4 and the version I sent you is a bit after that... it's very unlikely it will build with OpenFOAM 2.4.0. Best regards, Bruno Last edited by wyldckat; August 16, 2015 at 07:48. Reason: see "edit:" |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected | Djub | OpenFOAM Meshing & Mesh Conversion | 0 | July 15, 2014 05:43 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
