MPPICFoam DPMFoam clarifications
Like Tree27Likes
  • 27 Post By kenyi89
Old   May 20, 2015, 12:04
Default MPPICFoam DPMFoam clarifications
Jeroen Hofman
kenyi89 will become famous soon enough
Dear people,
I recently struggled to understand the DPMFoam and MPPICFoam solvers. I have written several reports on it for work and bundled them all here, including useful references. It can be a little chaotic as it is a collection of reports and I don't have time to rewrite them, however it describes some of the problems I encountered while trying to understand the solvers.
The report can be found here:
Jeroen
kenyi89 is offline   Reply With Quote
Old   April 7, 2016, 10:52
C-L
Charlie Lloyd
C-L is on a distinguished road
Ji Jeroen,
I have been using this solver over the last few months and your report on MPPICFoam has been really helpful over the last few weeks. The first few sections, classifying the continuum phase, were easy to follow. However, I am having issues in finding the equations you specify in the 'particle contributions section' in the solver code (DPMFoam). Is there a chance you can point me in the right direction?
Thanks in advance,
Charlie
C-L is offline   Reply With Quote
Old   April 17, 2016, 10:42
Jeroen Hofman
Dear Charlie,
These would be located in the particle libraries in OpenFOAM. I am at the moment no longer working on this though, so I can't exactly recall where they are. The files particle(Cloud), kinematicCloud, kinematicParcel contain the update algorithms. I think the velocity and position update are in particleCloud, from there you can backtrace where particle forces are applied .
Jeroen
Old   October 19, 2016, 02:55
Default MPPICFoam error in cyclone example of OpenFOAM
ali
ebtedaei is on a distinguished road
Dear All,
I run cyclone example in tutorials of the OpenFOAM version 4, but it has ERROR!!!
Why???
Please help me. I really need your help.
Thanks in advance.
ebtedaei is offline   Reply With Quote
Old   April 15, 2019, 12:22
Question Particle size or diameter
Ludo Masci
lumasci is on a distinguished road
I need to change the particle diameter of the MPPICFoam or DPMFoam solver. In my case, the particle grows over time. Do you have any idea how I could set this up?
  • DPMFoam, I guess I need to set V_p (equation (5)) varying over time.
  • MPPICFoam, I only see possible changes of m_p (equation (28)).
Do you have any hint to give me?
lumasci is offline   Reply With Quote
Old   June 19, 2021, 01:07
Yugal Sharma
Yugal Sharma is on a distinguished road
Hello, Dear Lumasci,
I am also using MPPCIFoam solver these days. I am facing the same difficulty as you.
Can you please elaborate here about any solution you found.
Yugal Sharma is offline   Reply With Quote
Collision spring stiffness value in DPMFoam maysmech OpenFOAM Programming & Development 11 March 25, 2022 23:53
DPMFoam - Interpretation of UcEqn.H kenyi89 OpenFOAM Running, Solving & CFD 5 January 14, 2021 14:28
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
MPPICFOAM - column tutorial crashing kenyi89 OpenFOAM Running, Solving & CFD 2 February 13, 2015 05:13
Unrealistic results using DPMFoam Mojtaba.a OpenFOAM Running, Solving & CFD 4 January 24, 2015 11:28
