January 29, 2015, 10:01 |
Different nu effects the amount of gravity?
Rickard Hidefjäll
Rep Power: 17 |
Hi look at http://youtu.be/ueMCheEpMrk
interMixingFoam with nu=1; in the square hanging in the air (marked as other. The colon on the left side have nu=1e-6 equal to water. The colon are falling faster than the square. It should be the other way around of the fact that the square just have air under and not water. And look at http://youtu.be/oKsIfmoJc6w interMixingFoam with nu=1e-6 in the square hanging in the air (marked as other. The colon on the left side have nu=1e-6 equal to water. The colon are now falling equal fast as the square, which it didn't in the other video http://youtu.be/ueMCheEpMrk . Is something wrong with the software? Or have I done some thing wrong? Here is the changes of the interMixingFoam : (I ran both it in parallel with 8 cores, but that should not effect the result. it took app. 45 minutes.) In transportProperties Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // phases (air other water); air { transportModel Newtonian; nu nu [0 2 -1 0 0 0 0] 1.48e-05; rho rho [1 -3 0 0 0 0 0] 1; } other { transportModel Newtonian; nu nu [0 2 -1 0 0 0 0] 1; //change this to 1e-6 to get the ohter simulation. rho rho [1 -3 0 0 0 0 0] 1010; } water { transportModel Newtonian; nu nu [0 2 -1 0 0 0 0] 1e-6; rho rho [1 -3 0 0 0 0 0] 1000; } // Surface tension coefficients sigma12 sigma12 [1 0 -2 0 0 0 0] 0.05; sigma13 sigma13 [1 0 -2 0 0 0 0] 0.04; // Diffusivity between miscible phases D23 D23 [0 2 -1 0 0 0 0] 3e-09; // ************************************************************************* // Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.air 1 volScalarFieldValue alpha.other 0 volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (0 0 -1) (0.1461 0.292 1); fieldValues ( volScalarFieldValue alpha.air 0 volScalarFieldValue alpha.other 0 volScalarFieldValue alpha.water 1 ); } boxToCell { box (0.2 0.3 -1) (0.4 0.5 1); fieldValues ( volScalarFieldValue alpha.air 0 volScalarFieldValue alpha.other 1 volScalarFieldValue alpha.water 0 ); } ); // ************************************************************************* // Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interMixingFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 5; deltaT 0.0001; writeControl adjustableRunTime; writeInterval 0.01; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression compressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; //adjustTimeStep no; maxCo 0.5; maxAlphaCo 0.5; maxDeltaT 1; // ************************************************************************* // Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.146; vertices ( (0 0 0) (2 0 0) (2.16438 0 0) (4 0 0) (0 0.32876 0) (2 0.32876 0) (2.16438 0.32876 0) (4 0.32876 0) (0 4 0) (2 4 0) (2.16438 4 0) (4 4 0) (0 0 0.1) (2 0 0.1) (2.16438 0 0.1) (4 0 0.1) (0 0.32876 0.1) (2 0.32876 0.1) (2.16438 0.32876 0.1) (4 0.32876 0.1) (0 4 0.1) (2 4 0.1) (2.16438 4 0.1) (4 4 0.1) ); blocks ( hex (0 1 5 4 12 13 17 16) (92 32 1) simpleGrading (1 1 1) hex (2 3 7 6 14 15 19 18) (76 32 1) simpleGrading (1 1 1) hex (4 5 9 8 16 17 21 20) (92 168 1) simpleGrading (1 1 1) hex (5 6 10 9 17 18 22 21) (16 168 1) simpleGrading (1 1 1) hex (6 7 11 10 18 19 23 22) (76 168 1) simpleGrading (1 1 1) ); edges ( ); boundary ( leftWall { type wall; faces ( (0 12 16 4) (4 16 20 8) ); } rightWall { type wall; faces ( (7 19 15 3) (11 23 19 7) ); } lowerWall { type wall; faces ( (0 1 13 12) (1 5 17 13) (5 6 18 17) (2 14 18 6) (2 3 15 14) ); } atmosphere { type patch; faces ( (8 20 21 9) (9 21 22 10) (10 22 23 11) ); } ); mergePatchPairs ( ); // ************************************************************************* // Last edited by wyldckat; January 29, 2015 at 16:49. Reason: Added [CODE][/CODE] |
January 29, 2015, 16:57 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Rickard,
This is so cool! It looks like a magic trick ! My best guesses without testing are:
I'll have a look into it during this coming weekend. But first a few questions:
Bruno
January 29, 2015, 17:47 |
Rickard Hidefjäll
Rep Power: 17 |
Hi!
And thanks! I use OpenFOAM 2.3.1 Kubuntu 14.04 i7 3.2Ghz (the first edition) 24Gb RAM (It took 45 minutes used all 8 core) Regards / Rickard Hidefjäll --------------- Sorry! Yes I do use the interMixingFoam tutorial case from start. Last edited by wyldckat; January 31, 2015 at 08:38. Reason: merged posts, since they were posted a minute apart |
January 31, 2015, 09:12 |
Bruno Santos
Rep Power: 128 |
Hi Rickard,
Well this is certainly an interesting test case that can showcase the importance of the dynamic viscosity (mu) between fluids. Here's an example of what I'm referring to: Code:
air { transportModel Newtonian; nu nu [0 2 -1 0 0 0 0] 1.48e-05; rho rho [1 -3 0 0 0 0 0] 1; } other { transportModel Newtonian; nu nu [0 2 -1 0 0 0 0] 1.48e-1; rho rho [1 -3 0 0 0 0 0] 1000; } water { transportModel Newtonian; nu nu [0 2 -1 0 0 0 0] 1e-6; rho rho [1 -3 0 0 0 0 0] 1000; } And why is the dynamic viscosity important? If you look at the values in the example above: Now, if you subtract the largest from the smallest: 1.48e2 - 1.48e-05 = 147.9999852 Notice anything strange yet? Well, it's simple: the solver was not designed to compensate for such large numerical discrepancies, because "147.9999852" is almost identical to "148", which means that the number of computational errors that occur due to this very small difference are far greater than the remaining values being calculated. If you increase even more to , the block barely moves. As time progresses, it then happens something very similar to this: http://www.cfd-online.com/Forums/ope...ckerboard.html Note: the reason for choosing for the "other" fluid was because I was confusing how dynamic and kinematic viscosity relate to each other. Conclusion: this is not a bug. It simply means that the solver was not designed to handle such large differences in the fluids' properties. Best regards, Bruno
Last edited by wyldckat; January 31, 2015 at 09:21. Reason: fixed mathematical expressions |
February 1, 2015, 18:09 |
Thanks a lot!
Rickard Hidefjäll
Rep Power: 17 |
Hi and Thanks for a fast and lightning response!
Do you have a suitable solver in mind? My goal is to simulate a new kind of toilette. Best regards / Rickard Hidefjäll |
February 3, 2015, 15:58 |
Bruno Santos
Rep Power: 128 |
Hi Rickard,
I've never used it myself, but perhaps multiphaseEulerFoam can get the job done? For more details: http://www.cfd-online.com/Forums/ope...eulerfoam.html Best regards, Bruno
February 3, 2015, 15:59 |
Rickard Hidefjäll
Rep Power: 17 |
Lots ofta tank !!!
bug?, intermixingfoam |
Convergence problem when use gravity | aroma | STAR-CCM+ | 1 | April 10, 2013 11:18 |
Question on Gravity | archdevil | Main CFD Forum | 9 | May 16, 2012 14:31 |
variation of gravity with time | rajani | FLUENT | 0 | February 16, 2005 03:45 |
On gravity modelling... | Drona | CFX | 7 | November 22, 2001 11:28 |
Effects of gravity in pipe - pressure distribution | Anthony Wachs | FLUENT | 2 | July 25, 2001 08:07 |
