September 4, 2014, 18:06 |
Bounding k and omega in OpenFOAM-1.6-ext
miladrakhsha
Rep Power: 14 |
Hello everyone,
I am using OpenFOAM-1.6-ext at this time and using kOmegaSST turbulent model. Is there anyway I can use "bounded" scheme in OpenFOAM-1.6-ext?? Code:
Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 0.00154947, Final residual = 4.86454e-05, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.00151971, Final residual = 4.23945e-05, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.01419, No Iterations 1 GAMG: Solving for p, Initial residual = 0.99997, Final residual = 0.000632842, No Iterations 10 time step continuity errors : sum local = 0.00157748, global = 1.86897e-10, cumulative = 1.86897e-10 DILUPBiCG: Solving for omega, Initial residual = 0.00764356, Final residual = 3.68028e-05, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.000621706, Final residual = 7.47442e-05, No Iterations 1 bounding k, min: -0.0002366 max: 0.775536 average: 0.0108005 |
September 8, 2014, 05:32 |
Philipp
Rep Power: 27 |
Try to use other gradient limiter and other gradient calculation method for k and omega. Such as cellLimited Gauss linear 1, faceMDLimited edgeCellsLeastSquares 1, ... There are a lot of possible combinations.
I know this needs a lot of trial and error, but in my experience this works.
The skeleton ran out of shampoo in the shower. |
September 8, 2014, 14:01 |
miladrakhsha
Rep Power: 14 |
Thank you for the response, I am actually using upwind scheme for the k and omega which I believe should be stable enough because of being diffusive. Here is my fvScheme file Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default Gauss upwind; div(phi,U) Gauss linearUpwind cellLimited Gauss linear 1; div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; div(phi,nuTilda) Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; div((nuEff*dev(grad(U).T()))) Gauss linear; div(R) Gauss linear; } laplacianSchemes { default Gauss linear corrected; laplacian(nuEff,U) Gauss linear limited 0.5; laplacian((1|A(U)),p) Gauss linear limited 0.5; laplacian(DkEff,k) Gauss linear uncorrected; laplacian(DepsilonEff,epsilon) Gauss linear uncorrected; laplacian(DomegaEff,omega) Gauss linear uncorrected; laplacian(DREff,R) Gauss linear limited 0.5; laplacian(DnuTildaEff,nuTilda) Gauss linear limited 0.5; //potentialFoam laplacian(1,p) Gauss linear limited 0.5; } interpolationSchemes { default linear; interpolate(HbyA) linear; } snGradSchemes { default bounded; } fluxRequired { default no; p; } // ************************************************************************* // I would appreciate it Milad |
September 9, 2014, 03:17 |
Philipp
Rep Power: 27 |
1) What solver do you use? 2) What boundary conditions? 3) In my experience changing the convective scheme doesn't solve the k and omega bounding problem. Here, it was always the gradient+limiter. 4) How do the solver settings of fvSolution look like? Edit: Just try Code:
grad(k) faceLimited edgeCellsLeastSquares 1; grad(omega) faceLimited edgeCellsLeastSquares 1;
The skeleton ran out of shampoo in the shower. Last edited by RodriguezFatz; September 9, 2014 at 06:04. |
September 9, 2014, 12:08 |
miladrakhsha
Rep Power: 14 |
I am experiencing with simpleIbFoam which is the modification of simpleFoam for Immersed body method, the boundary conditions are validated using simpleFoam solver. However, for the immersed body I have something like this for
U: Code:
VGIB { type immersedBoundaryWallFunction; patchType immersedBoundary; refValue uniform (0 0 0); refGradient uniform (0 0 0); fixesValue yes; value uniform (0 0 0); setDeadCellValue yes; deadCellValue (0 0 0); } Code:
VGIB { type immersedBoundary; refValue uniform 0; refGradient uniform 0; fixesValue no; //value uniform 0; setDeadCellValue yes; deadCellValue 0; value uniform 0; } Code:
VGIB { type immersedBoundaryWallFunction; patchType immersedBoundary; refValue uniform 1e-10; refGradient uniform 0; fixesValue no; value uniform 1; setDeadCellValue yes; deadCellValue 1e-10; } Code:
VGIB { type immersedBoundaryWallFunction; patchType immersedBoundary; refValue uniform 1e-8; refGradient uniform 0; fixesValue no; value uniform 1e-10; setDeadCellValue yes; deadCellValue 1e-8; } It is worth mentioning that I have tried immersedBoundaryOmegaWallFunction but for some reason it does not work correctly. And finally this is my fvSolution file: Code:
p { solver GAMG; tolerance 1e-06; relTol 0.001; minIter 1; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 2000; } U { solver PBiCG; preconditioner DILU; minIter 1; maxIter 1000; tolerance 1e-06; relTol 1e-001; } k { solver PBiCG; preconditioner DILU; minIter 0; maxIter 1000; tolerance 1e-06; relTol 0.001; } omega { solver PBiCG; preconditioner DILU; minIter 0; maxIter 1000; tolerance 1e-06; relTol 0.001; } epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-20; relTol 1e-01; } } potentialFlow { nNonOrthogonalCorrectors 20; pRefCell 0; pRefValue 0; } SIMPLE { nCorrectors 0; nInitialNonOrthogonalCorrectors 20; nNonOrthogonalCorrectors 0; //pRefPoint (1 1 0); pRefCell 0; pRefValue 0; residualControl { p 1e-9; U 1e-10; "(k|epsilon|omega)" 1e-10; } } relaxationFactors { p 0.3; //era 0.2 U 0.5; k 0.5; omega 0.5; } Milad |
September 9, 2014, 12:18 |
miladrakhsha
Rep Power: 14 |
I gave the scheme you told me a shot but an error is returned :
--> FOAM FATAL IO ERROR: unknown grad scheme edgeCellsLeastSquares Valid grad schemes are : 9 ( fourth cellMDLimited Gauss cellLimited beGauss faceMDLimited faceLimited extendedLeastSquares leastSquares ) file: /home/milad/Desktop/IBMVALIDATION/system/fvSchemes::gradSchemes::grad(omega) at line 26. |
September 10, 2014, 07:52 |
Philipp
Rep Power: 27 |
Ok, then try leastSquares instead, I didn't know your version is missing that.
Are you sure you use the correct syntax for relaxation factors? I just remember, that different solvers need different syntax. Did you try to use "(p)" 0.3; ... ?
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 07:54 |
rhoSimpleFoam convergence problem - bounding omega | inf.vish | OpenFOAM Running, Solving & CFD | 1 | October 20, 2020 09:20 |
Bounding epsilon or bounding omega | Stylianos | OpenFOAM | 8 | February 23, 2018 14:41 |
Bounding OMEGA | barath.ezhilan | OpenFOAM | 3 | April 20, 2012 12:06 |
k Omega SST SAS for OpenFOAM 1.5??? | barath.ezhilan | OpenFOAM Running, Solving & CFD | 3 | June 2, 2010 08:41 |
