Slow heat transfer in solid regions (chtMultiRegionSimpleFoam)
Like Tree1Likes
  • 1 Post By slottedLemon
Old   June 20, 2014, 09:07
Default Slow heat transfer in solid regions (chtMultiRegionSimpleFoam)
Sven
SvenH is on a distinguished road
I tried to convert the tutorial "chtMultiRegionHeater" to a steady-state case. It has now two solid regions (heater and rightSolid), one fluid region (air/domain0) and a symmetryPlane. The heater has a heat source.
It seems to work fine on the fluid side. But the solid regions are heating up / cooling down very slow and I can't figure out why.
I uploaded the whole case and screenshots whit this Post. Every help is welcome.
SvenH is offline   Reply With Quote
Old   June 30, 2014, 13:14
Alex
zfaraday will become famous soon enough
Hello Sven!
Thermal convergence may be quite slow with chtMultiRegionSimple Foam. Take a look at these threads
http://www.cfd-online.com/Forums/ope...x-utility.html
http://www.cfd-online.com/Forums/ope...tml#post338430
I haven't taken a look into your case but I'm sure you will find the solution in th links above.
Cheers!
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   July 23, 2014, 19:05
Robin
slottedLemon is on a distinguished road
Hi Sven,
I had a similar problem recently, which is how I came across this post. I upped the underrelaxation for h in the solid region to 1.0, I imagine that this would be stable under most if not all conditions. Not sure why it's so low in the tutorials. Anyway, it seems to be working for me, 6 degrees of change in the first 17000 iterations became 100 degrees in the following thousand. Reducing the tolerance (increasing the iterations) in the solid region didn't seem to do much for me.
Robin
Zaphod'sSecondHead likes this.
slottedLemon is offline   Reply With Quote
requiring solution for heat transfer from gas to solid particle in cyclone suvai79 FLUENT 0 September 1, 2012 06:48
Solid to Fluid Heat Transfer Modelling Problem bortonj88 Main CFD Forum 3 November 14, 2011 15:21
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
