InterFoam fails to predict suspended stationary liquid column in capillary channel |
April 11, 2014, 17:14 |
Ovie Doro
Rep Power: 17 |
Hi:
I have a set up where a slug of liquid (water) is suspended in a vertical capillary channel open to the atmosphere at both ends. Experimental results from our lab shows that the liquid is unable to flow under its weight without agitating the channel. However, when I run simulations using interFoam for the set up, the liquid easily flows under the influence of gravity (see attached file for 2D case). I guess the question is should the no-slip boundary condition be used in this case or should it be replaced by some friction dependent bc that accounts for the effect of a static friction barrier that must be overcome before liquid starts flowing? Thanks. |
April 13, 2014, 18:15 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Ovie,
I haven't managed to look into this, but I'm still curious... I'm making a note to come back to this in a few days. Anyway, my guess is that you did not initialize properly the pressure field. The other possibilities that come to mind are:
Best regards, Bruno
April 13, 2014, 21:39 |
#3 | |
Ovie Doro
Rep Power: 17 |
The set up for the 2-D version of this problem is adapted directly from the "Capillary Rise" tutorial - so i used the same set of the initial conditions. I also retained the same mesh resolution as was used in the tutorial. The dimensions have been double checked and they are ok too. The suggestion to turn off gravity at first sounds good. I would try this out and let you know the outcome. Thanks again! |
April 14, 2014, 16:25 |
#4 | |
Ovie Doro
Rep Power: 17 |
Hi: I just repeated the simulations with/without gravity. The case with gravity was ok i.e. liquid remains suspended in capillary channel. I ran this for enough time to ensure the solution is stable. Then I restarted with gravity turned on and the liquid slug starts flowing downwards. The liquid slug has a volume of 5microL and the channel volume is 70microL. The velocities from the interFoam solution approach values from Poiseuille flow which is really high for channels of this dimension. I dont think these results are correct. Thanks. |
April 14, 2014, 17:00 |
#5 | |
Bruno Santos
Rep Power: 128 |
Hi Ovie,
Mmm... I think you might be hitting the limitation mentioned on these posts:
Bruno |
April 20, 2014, 12:18 |
Bruno Santos
Rep Power: 128 |
Hi Ovie,
I finally managed to give a look into this. Just to be clear, I'm not an expert on this, but I believe that you can't use a constant alpha angle, given that it oscillates that much. You'll need to search more about this, but the "dynamicAlphaContactAngle" seems to be what you should be using for the walls. For example (a somewhat bad one I tried): Code:
walls { type dynamicAlphaContactAngle; theta0 45; uTheta 10; thetaA 10; thetaR 60; limit gradient; value uniform 0; } Code:
//- Equilibrium contact angle scalar theta0_; //- Dynamic contact angle velocity scale scalar uTheta_; //- Limiting advancing contact angle scalar thetaA_; //- Limiting receeding contact angle scalar thetaR_; Bruno
April 21, 2014, 17:17 |
#7 | |
Ovie Doro
Rep Power: 17 |
Thanks for looking into this. I would implement the dynamic contact angle BC and let you know the results. Thanks again! |
April 21, 2014, 17:37 |
#8 | |
Bruno Santos
Rep Power: 128 |
Hi Ovie,
I forgot to mention that you might need to do some more research on this topic, as implied by this paper: Impacting droplets: dynamic contact angle modelling in OpenFOAMŪ - this paper indicates that another model had to be implemented by the paper's authors in order to better simulate the following: Quote:
Best regards, Bruno |
April 21, 2014, 17:55 |
#9 |
Ovie Doro
Rep Power: 17 |
Great! Thanks!
July 2, 2019, 09:45 |
Kistler model - dynamic contact angle
#10 | |
Ludo Masci
Rep Power: 8 |
Hi, Old topic, I know, but still a current topic. Did anyone try to implement the Kistler model for theta_dyn? I am having issues with a droplet rolling down an inclined plane. |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 16:26 |
