icoUncoupledKinematicParcelFoam - strange thing
Like Tree4Likes
  • 1 Post By Tobi
  • 2 Post By sanjar
  • 1 Post By ronithstanly
Old   January 11, 2014, 12:28
Default icoUncoupledKinematicParcelFoam - strange thing
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I am building an hydro-cyclone and simulated it with simpleFoam. Now I want to add particels and want to use the solver icoUncoupledKinematicParcelFoam.
The solver is adding particels but after 4 added - no particel is in the domain anymore?:
Time = 0.006
Evolving kinematicCloud
Solving 3-D cloud kinematicCloud
    531 move-collide subCycles
Cloud: kinematicCloud
    Current number of parcels       = 2
    Current mass in system          = 0.000916088
    Linear momentum                 = (0.000388678 0.00668253 0.00395061)
   |Linear momentum|                = 0.00777268
    Linear kinetic energy           = 0.0574843
    Rotational kinetic energy       = 0.0325214
    model1:
        number of parcels added     = 2
        mass introduced             = 0.000916088
    Parcels absorbed into film      = 0
    New film detached parcels       = 0
ExecutionTime = 606.33 s  ClockTime = 628 s
Time = 0.0061
--> Cloud: kinematicCloud injector: model1
    Added 1 new parcels
    530 move-collide subCycles
    Current number of parcels       = 0
    Linear momentum                 = (0 0 0)
    model1:
        number of parcels added     = 3
        mass introduced             = 0.00137413
ExecutionTime = 615.79 s  ClockTime = 638 s
Well I have not many experiance with that solver - especially with the settings I have to make in the Cloud file. I showed the variables in red I am not 100% sure of the meaning. Maybe someone can clear my mind:
My file is the following:
solution
    active          true;
    coupled         false;
    transient       yes;
    cellValueSourceCorrection off;
    interpolationSchemes
        rho             cell;
        U               cellPoint;
        mu              cell;
    integrationSchemes
        U               Euler;
constantProperties
    rho0            1.2;           // Air + particel load ?
    youngsModulus   6e8;   // not sure about
    poissonsRatio   0.35;    // not sure about
subModels
    particleForces
        sphereDrag;
        gravity;
    injectionModels
        model1
            type            patchFlowRateInjection;
        patchName        inlet;
        duration        2;
        concentration   0.6;              // parcel concentration in my fluid?
            parcelsPerSecond 500;
        meanParticleDiameter 0.003;  // for what?
        nParticle        1000;            // max particle in domain ?
            massTotal       0.5;           // max mass in the domain ?
            parcelBasisType fixed;    // dont know
            SOI             0;                     // ?
            sizeDistribution
                type        fixedValue;          // particle have fixed sizes
                 fixedValueDistribution        // the sizes the particels can have ?
                    value   0.006;
            value   0.01;
                    value   0.001;
                    value   0.015;
            value   0.004;
            value   0.009;
    dispersionModel none;
    patchInteractionModel none;
    surfaceFilmModel none;
    collisionModel pairCollision;
    pairCollisionCoeffs
        maxInteractionDistance  0.006;
        writeReferredParticleCloud no;
        pairModel pairSpringSliderDashpot;
        pairSpringSliderDashpotCoeffs
            useEquivalentSize   no;
            alpha               0.12;
            b                   1.5;
            mu                  0.52;
            cohesionEnergyDensity 0;
            collisionResolutionSteps 12;
        wallModel    wallLocalSpringSliderDashpot;
        wallLocalSpringSliderDashpotCoeffs
            ".*Wall"
                youngsModulus   1e10;
                poissonsRatio   0.23;
                alpha           0.12;
                b               1.5;
                mu              0.43;
Are there any tutorials available (not the hopper one?)
Maybe I have to use a other particel solver for my problem?
Thanks in advance
Tobi
ronithstanly likes this.
Tobi is offline   Reply With Quote
Old   January 15, 2014, 21:55
liyu
ahliyu is on a distinguished road
hello, Tobi.
actually, i can not help you very much, because i am a rookie.
but i know, "SOI" means " start of injection". specifically, in your code, it means model1 begins to inject particles at 0 second.
" nParticle" means the number of particles that one parcel contains.
"massTotal" dose not determine anything when you set the "parcelBasicType" as "fixed".
ok, that is all i can do for you.
best regards.
ahliyu is offline   Reply With Quote
Old   January 15, 2014, 23:07
liyu
hello, Tobi.
best regards.
Old   January 16, 2014, 11:29
ziehjay
sanjar is on a distinguished road
Hello Tobias,
i guess we know each other. Here are some of the information you need referring to your problem with the meaning of some of the aspects concering the cloud-File.
constantPoperties
youngsModulus 6e8;          // E-Modul
poissonsRatio 0.35;          // Poissonzahl
I just worked with patchInjection as injectionModel and not with patchFlowRateInjection, so in the following these information can be provided referring to this part:
nParticle: total amount of particles you want to inject
massTotal: total mass of the particles in kg
SOI: Start of Injection (when particles are loaded on the streamlines of your main-fluid-flow
pairCollisionCoeffs
maxInteractionDistance: maximal distance of action between particles (max. Beeinflussungsdistanz)
wallModel wallLocalSpringSliderDashpot: describes the influence of particle with the wand (Partikel-WandStoß)
collisonReslutionSteps 12
youngsModuls: E-Modul
b: Federgesetzexponent
alpha: Restitution coefficient
poissonsRatio: Poissonnumber
mu: Reibungskoeffizient
cohesionEnegryDistance: Bindungsenergie [J/m³]
I hope i could help you a liitle bit. Maybe somebody else is/was also working with icoUncoupledKinematicParcelFoam and know the rest od the meanings.
Greetings, Sanjar
oumnion and ronithstanly like this.
sanjar is offline   Reply With Quote
Old   August 24, 2015, 05:58
Ameya T is on a distinguished road
Hi Tobias,
Were you able get answers to your doubts? I am interested to know.
Ameya T is offline   Reply With Quote
Old   October 5, 2017, 09:20
Smile alpha is not equal to coefficient of restitution
Ronith Stanly
ronithstanly is on a distinguished road
Hi Sanjar,
The information you provided on this topic is quite useful however, I found an error and I would like to mention it so that others won't end up disappointed after simulating and probably they will not have to endlessly try different settings to find the bug.
The "alpha" is not equal to the coefficient of restitution, but they are related as shown in Fig.4 page 243 of Y. Tsuji, T. Tanaka, T. Ishida, Lagrangian numerical simulation of plug flow of cohesionless particles in a horizontal pipe, Powder Technology, Volume 71, Issue 3, September 1992, Pages 239-250, ISSN 0032-5910, https://doi.org/10.1016/0032-5910(92)88030-L.
(http://www.sciencedirect.com/science...3259109288030L)
For example (taken from that graph), if Coefficient of Restitution=1, then alpha=0.01.
Hope this will help some others
Regards,
Ronith Stanly
HenrikJohansson likes this.
ronithstanly is offline   Reply With Quote
Strange Nut behaviour with K-OmegaSST nicolarre OpenFOAM Running, Solving & CFD 12 March 19, 2019 21:35
Strange residuals behaviour xxxx Main CFD Forum 1 July 13, 2013 15:40
A strange thing on Compaq Visual Fortran archdevil Main CFD Forum 7 May 17, 2012 07:38
A Strange Problem in making Parallel (Ansys/CFX 12) a.sarami CFX 13 October 7, 2010 02:33
Strange things in SRF (urgent) Cem FLUENT 0 December 19, 2005 11:37
