Modified tutorial 3D to 2D; pimpleDyMFoam crashing
Like Tree1Likes
  • 1 Post By nimasam
Old   June 24, 2013, 03:13
Default Modified tutorial 3D to 2D; pimpleDyMFoam crashing
Anand Lobo
Boloar is on a distinguished road
Hi everyone.
I'm very much an OpenFOAM beginner, so advice here would really be appreciated.
With a lot of effort, I repurposed the tutorial incompressible/pimpleDyMFoam/propeller to model a wind turbine in 2D. Or at least I've attempted to.
After running snappyHexMesh, the checkMesh utility gives me these errors:
 ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
 ***Number of edges not aligned with or perpendicular to non-empty directions: 102515
In addition (or perhaps, as a result of this), the pimpleDyMFoam solver crashes almost immediately on starting with a floating point exception.
My case files are attached for your perusal.
Thanks in advance for any help!
Boloar is offline   Reply With Quote
Old   June 24, 2013, 08:11
Nima Samkhaniani
nimasam is on a distinguished road
Dear anand
you are going to solve a 2D problem, so your mesh should have just one cell thick,
after snappyHexMesh, you should use extrudeMesh to create a true 2D geometry
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 25, 2013, 06:37
Question Mesh is proper 2D! pimpleDyMFoam still crashing
Anand Lobo
Hi nimasam,
Thanks for that, I had not realized that. The mesh is now correct.
I am still unable to figure out why pimpleDyMFoam keeps crashing, though.
I have redone my case, and borrowed several of the boundary and initial conditions from the incompressible/pimpleDyMFoam/wingMotion tutorials. It keeps crashing almost immediately, giving the error below. I'm sure it has to do with the initial conditions, since it crashes immediately after reading k, but all of them seem valid to me ...
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.0-5be49240882f
Exec   : pimpleDyMFoam
Date   : Jun 25 2013
Time   : 15:00:48
Host   : "fedorael"
PID    : 9244
Case   : wingMotion/pimpleDyMFoam
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone AMIsurface_z
Reading field p
AMI: Creating addressing and weights between 1536 source faces and 1536 target faces
AMI: Patch source weights min/max/average = 0.04771037154, 1, 0.9089661396
AMI: Patch target weights min/max/average = 0, 1.632719212, 0.9069578828
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
bounding k, min: 0 max: 37 average: 37
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
 at sigaction.c:?
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  void Foam::divide<Foam::fvPatchField>(Foam::FieldField<Foam::fvPatchField, double>&, Foam::FieldField<Foam::fvPatchField, double> const&, Foam::FieldField<Foam::fvPatchField, double> const&) at ??:?
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#6  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::average<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#7  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::average<double>(Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) at ??:?
#8  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::average<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#9  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::average<double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#10  Foam::bound(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensioned<double> const&) at ??:?
#11  Foam::incompressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) at ??:?
#12  Foam::incompressible::RASModel::adddictionaryConstructorToTable<Foam::incompressible::RASModels::kOmegaSST>::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) at ??:?
#13  Foam::incompressible::RASModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) at ??:?
#14  Foam::incompressible::turbulenceModel::addturbulenceModelConstructorToTable<Foam::incompressible::RASModel>::NewturbulenceModel(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) at ??:?
#15  Foam::incompressible::turbulenceModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) at ??:?
#16
 at ??:?
#17  __libc_start_main at ??:?
#18
 at ??:?
Floating point exception (core dumped)
Any idea how to fix this? Case files are attached.
Old   June 27, 2013, 12:29
kilroy's Avatar
kilroy is on a distinguished road
Anand,
Have you tried to clean your "/constant/polyMesh/" folder? Maybe you still have some excess files in that folder from your previous runs.
Best,
Kilroy
kilroy is offline   Reply With Quote
Old   June 28, 2013, 01:40
Anand Lobo
Hi Kilroy,
I've removed any and all irrelevant files, to the best of my knowledge. Meshing is perfect, as far as I can tell, and pimpleDyMFoam still crashes. No previous runs - I haven't even got one successful run yet, lol
Old   June 29, 2013, 02:46
Question
Anand Lobo
I've tried changing the relaxation factors, the solvers, the schemes, the initial condition values, anything I could.
Nothing works, it keeps getting a floating point exception in exactly the same spot: immediately after reading k. The bounding value of k goes from 0 to 37, and evidently it doesn't like that zero, according to the error report.
I have NO idea how to fix this. Help will be deeply appreciated.
Old   June 29, 2013, 02:48
kilroy's Avatar
I will try to look into your case on Monday and let you know if I can some errors. Have a nice weekend!
Old   June 29, 2013, 02:55
Anand Lobo
Thank you Kilroy!
Background info on the case: I modified the incompressible/pimpleDyMFoam/propeller 3D tutorial into a 2D form with my own STL files, to take advantage of the AMI implementation, and it seems correct.
Then I intended to use that AMI-enabled mesh with the pimpleDyMFoam/wingMotion airflow conditions - but it keeps crashing.
It seemed plausible in concept, I hope it can be resolved.
UPDATE:
Okay, so maybe I'm stupid. I had defined the AMI regions (type cyclicAMI;) in the initial conditions 0/include/AMI, but I foolishly forgot to assign a value to them i.e. value $internalField. Now the solver goes past that stage and crashes slightly later with exactly the same error.
Date   : Jun 29 2013
Time   : 15:51:28
Host   : "fedorael"
PID    : 14108
nProcs : 1
Create time
Reading field p
Reading field U
kOmegaSSTCoeffs
    alphaK1         0.85034;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.85616;
    gamma1          0.5532;
    gamma2          0.4403;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
Reading field rAU if present
Creating finite volume options
No finite volume options present
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Starting time loop
Courant Number mean: 12.53463609 max: 353.4174513
deltaT = 0.00025
Time = 0.00025
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.00025 transformation: ((0 0 0) (0.9999996916 (0 0 0.0007853980827)))
AMI: Patch source weights min/max/average = 0.06740513704, 2.343027326, 1.197313318
AMI: Patch target weights min/max/average = 0, 2.317230511, 1.190243699
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.01249677062, No Iterations 7
time step continuity errors : sum local = 1.535166181e-06, global = -2.375415942e-08, cumulative = -2.375415942e-08
PIMPLE: iteration 1
 at sigaction.c:?
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4  void Foam::divide<Foam::fvPatchField>(Foam::FieldField<Foam::fvPatchField, double>&, double const&, Foam::FieldField<Foam::fvPatchField, double> const&) at ??:?
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
 at ??:?
#7  __libc_start_main at ??:?
 at ??:?
Old   July 3, 2013, 04:50
Anand Lobo
After my minor breakthrough about the initial conditions file, I haven't made any progress ... any luck, Kilroy? (or anyone else who may have taken a look at the case?)
For the life of me I can't figure out where that division error is coming from.
Old   July 3, 2013, 05:28
Nima Samkhaniani
Dear annad
problem is somewhere else , it returns to your poor AMI BC,
now solver is going to map to a face with weight 0 and its not possible ,
so its better that you work on your meshing and create AMI with weighting around 1
Old   July 3, 2013, 06:16
Anand Lobo
Hi nimasam,
I think I see what you mean. But I'm not sure how to fix that ... Do I need to increase the snappyHexMesh refinement levels? Change the AMI tolerance or rotational velocity?
I tried to copy the AMI setup of the propeller tutorial as closely as possible.
Old   July 3, 2013, 06:21
Nima Samkhaniani
i think you should work on snappyHexMesh, to create much more uniform AMI faces,
did you use stl file to create cylinder? or you may want to use edgeSnappFeature, to have better edge resolution
Old   July 3, 2013, 06:28
Anand Lobo
I've increased the "feature edge refinement" in sHM from 2 levels to 4. Yes, I used a cylinder STL file to define the AMI where it intersects with the blockMesh ... would it work better if I implemented it as a "searchableCylinder" instead?
Could you elaborate a little bit on the edgeSnappFeature you just mentioned?
Old   July 3, 2013, 06:45
Default propeller
  #14
Nima Samkhaniani
enjoy it
Boloar likes this.
Old   July 3, 2013, 07:00
Anand Lobo
enjoy it
You, sir, are a God among men. I honestly would never have thought to reduce the sHM refinement
Thank you!
Modified the motorBike tutorial, getting very high drag ben1793 OpenFOAM Running, Solving & CFD 4 August 16, 2013 03:25
pimpleDyMFoam issue giovanidiniz OpenFOAM Running, Solving & CFD 1 July 5, 2013 08:25
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
